Weird no start issue????
Old Oct 17, 2011 | 08:04 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Well, I took my truck into the local diesel place to have it checked out. they replaced the fuel lines and pump which fixed up my fuel leak issues. They also replaced my ICP and CPS. Picked it up Friday afternoon, went and got new tires, and then drove out with some stuff to my girlfriends horse show. Everything was runnin good.
A few hours later we all got in the truck to go to diner and no start. No cranking at all, just one solid clunk when i turned the key to start, no tac movment. Batteries were fine as all electronics worked. About an hour later i came back and tried it again. It gace that solid clunk, then about 1 second after the starter came to life and she fired right up. Since then shes been running good as usual. Whats the deal?
Old Oct 17, 2011 | 08:15 PM
F350-6's Avatar
F350-6
One big clunk when the key is turned is usually a voltage issue. Sounds like it's time to clean the battery cables (don't forget the grounds and that each cable has 2 ends).
Old Oct 17, 2011 | 09:41 PM
Devore95's Avatar
Devore95
this sounds pretty dumb but i just bought a 97 f350 and the guy said he put a new starter on it but all it would do it clunk then nothing would happen. i messed with it for about an hour and it turned out the top bolt of the starter was loose and only would ground out sometimes so i tightned it and it is as good as new. starts every time.
Old Oct 17, 2011 | 10:34 PM
Action4478's Avatar
Action4478
It sounds like a starter or a starter solenoid to me ...
Old Oct 18, 2011 | 12:11 AM
Ford4Life7.3
Alright ill check that out tomorrow, thanks. How hard is the bolt to get to?
Brother Les
May 24, 2010 01:15 PM
messeswithtrux
Mar 5, 2010 11:19 PM
travisd
Sep 15, 2009 04:36 AM
gordo777
Nov 20, 2007 09:11 AM
Skiffer
Aug 2, 2004 06:07 PM
