Shes giving me starting issues.
Old Oct 17, 2011 | 08:41 AM
Rollin.IH.Coal's Avatar
Rollin.IH.Coal
Question Shes giving me starting issues.
Hey guys, same ol 86 6.9. i finally dragged her down the road with the injector lines cracked, then tightened em and popstarted her. fired right up... gor her into opperating temp, shut her down and immeadiatly fired her up and she did. then an hour later fired right up. 2 after that and she hessitated a bit then fired up. then 3 after that cranks for about 30 seconds then fires up. over night im at step one? whats wrong am i still sucking air?
Old Oct 17, 2011 | 10:49 AM
86f250XLT-4x4's Avatar
86f250XLT-4x4
Did you check to see if you had air at your schrader valve?
Old Oct 17, 2011 | 11:32 AM
Rollin.IH.Coal
thats the tire valve on the fiel filter?
Old Oct 17, 2011 | 12:26 PM
86f250XLT-4x4
Yes that one lol
Old Oct 17, 2011 | 01:42 PM
josh'sdeisel's Avatar
josh'sdeisel
check your lift pump
Old Oct 17, 2011 | 01:55 PM
Rollin.IH.Coal
what would i even check on my lift pump how would i even test it. also i was thinking about getting a little 30gph 3-5psi lift pump to prime her run it to a dashswitch
Old Oct 17, 2011 | 01:56 PM
Rollin.IH.Coal
and yeah i bled the scherader valve lol
Old Oct 17, 2011 | 04:57 PM
tecgod13's Avatar
tecgod13
Are the glow plugs working yet???????????
Old Oct 17, 2011 | 10:31 PM
greywynd's Avatar
greywynd
Also, just how fast is this thing cranking over? Might be more starter speed/wiring than anything else.
Old Oct 18, 2011 | 09:22 AM
Rollin.IH.Coal
shes crainking over pleanty fast lol. i just have a leak from one cyl return line cap. i thought shed start through that tho..
TriednTrueFordBlue
Dec 10, 2015 06:39 PM
BKF250
27
Apr 21, 2010 01:15 PM
fordguy_460
41
Feb 7, 2010 07:15 PM
tbenks
Dec 16, 2009 04:02 PM
Rusty Hooks
Dec 12, 2005 04:50 PM
