Stumped....??
Old Dec 12, 2005 | 12:16 PM
Rusty Hooks's Avatar
Rusty Hooks
Stumped....??
OK...another newbie here....just found you guys
I've had my 86 6.9 for almost 20 years...never a problem that a little regular maint wouldn't take care of...
Now...no start, my son ran it out dry and haven't been able to get it to pick up ever since...replaced batteries(needed them anyway) filter, drain back lines, o-rings, removed the water separator....bled out the lines....no spray but on one cylinder...
Haven't checked the check valve yet but I'm after that this evening...
ip solenoid clicks ok, turns over like a bat outta _____, won't pick up....?
air bled out at the filter, plenty of low pressure,......not alot of pressure at the injector lines when bled out.
scratching my bald head....?
Old Dec 12, 2005 | 12:26 PM
smiller4597's Avatar
smiller4597
Possible that when it was run dry it picked up crud from bottom of tank and plugged fuel line???
Old Dec 12, 2005 | 01:08 PM
PLC7.3's Avatar
PLC7.3
Open the schrader valve on the Filter header by removing the core (tire valve), ensure there is over 1/4 fuel in the tank selected. Place a hose on the Schrader valve and duct it to a container, now crank engine for 15 seconds. Fuel should now be at the filter header, always fill the new filter with clean diesel via the small round holes BEFORE installing. Does the FSS on the IP have power.....check all connectors for power 9V with key on. How long does WTS light stay on......5-10 secs depending on ambient temps. Start immediately after WTS goes out
Old Dec 12, 2005 | 01:26 PM
Rusty Hooks
Haven't pulled the schrader valve yet...tonight....
Have fuel to the filter and bled out the air through the valve...
when I removed the water separator I unplugged the electrical connection...does that need a special termination tie, will it interfere with the system?
I think I'm doomed to remove the tanks next to check the filters and replace the sending units....at 60 I'm not looking forward to under the belly of the beast again...lol...
trying to keep a reasonable sense of humor...
this truck was going to be sold and stopped cold...It likes me too much
I shouldn't have let it see the 03 7.3 in the driveway!!
Old Dec 12, 2005 | 02:22 PM
smiller4597
Wait To Start
Old Dec 12, 2005 | 04:41 PM
bilder12's Avatar
bilder12
if you needed a jump start and you used one power cord on both batteries, you may have fried the shut off solenoid... thus no fuel to lines. when you activate the key switch, do you hear the shut off clicking on and off ??
Old Dec 12, 2005 | 04:50 PM
Rusty Hooks
I'm real careful about jumping...only passenger side...installing a plug on the new one..(03)
key does click ip solenoid, fuel flow to the filter...it may just be the bleed down from the drain line to the filter...I'll remove it tonight.
I wish I'de had this forum a long time ago....
Redneckfordf2502002
Mar 10, 2014 10:41 AM
ROKRAWL
Nov 11, 2012 06:31 PM
swooshcmk
Jul 22, 2011 08:24 PM
dmyers
Sep 10, 2010 06:19 AM
booputt44
Feb 15, 2005 02:56 PM
