Rear air problem / conversion van
Old Oct 17, 2011 | 07:34 AM
Bukiman's Avatar
Bukiman
I have a 96 E 150 Imperial conversion van with Pro Air rear air unit, the fan works at all speeds and I can hear it running from the front seat, but I don't seem to be getting air out of ceiling vents, can barely feel air coming out, if I hold a piece of paper against the coil in the rear, it does suck the paper to it, but....... nothing out of the vents ??
Am baffled, any help appreicated
Love this forum, it has helped me numerous times.
Old Oct 18, 2011 | 06:14 AM
JWA's Avatar
JWA
Along with this forum try the Cooling, Heating, Ventilation & A/C forums too---under the Misc category from the drop down forum jump box at the bottom here.
It's possible the duct tube from the blower outlet has slipped off the overhead supply ducts------that's the first thing that comes to mind especailly if you see some sort of intake action. If you can remove the trim panel covering the blower unit you might see something that stands out.
Old Oct 18, 2011 | 07:34 AM
Bukiman's Avatar
Bukiman
Air
That's the same thing I was thinking, will start demo tomorrow, was hoping someone could tell me exactly where to start.
Thanks
Old Oct 19, 2011 | 04:40 AM
JWA's Avatar
JWA
Your job demo'ing should be a bit easier with the conversion van as opposed to the standard Ford Club Wagon or Chateau interior with the factory rear heater & A/C overhead vents etc since access should be via a single panel covering the core and blower.
Shouldn't be too tough to find and fix. I used a mylar tape around extra ducting I ran overhead in my cargo van---two years later its still stuck quite well, not showing any signs of deteriorating at all.
brian.taylor
Mar 9, 2010 05:44 AM
Texas Mad Man
Dec 23, 2008 07:03 PM
newo2u
Apr 24, 2008 05:14 PM
75c3
Aug 30, 2003 06:34 AM
