EFT Installed - Got some data runs
Old Oct 16, 2011 | 11:48 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Did some data runs today after doing my EGT probe install. Really neat feature, but alarming data as well (sorta)
0mph with WOT to 60 mph: Rockets from 200F to 1400F
30-35 mph cruising in town: 400-500F
55-60 mph cruising on highway: 550-750F
550F on level ground
fluctuates from 550-750F with minimal change in grade (low boost). coasting downhill saw 400F a few times
While accelerating, it is typical to see 700-900F with minimal throttle. Once you reach your desired speed, the temps drop out quickly. Is that normal? Seems really high when most people quote 1,200F as the upper limit. Truck is bone stock from intake to exhaust tip except for Kitty delete and Gearheads SLR tune.
Old Oct 16, 2011 | 11:50 PM
ol-blu's Avatar
ol-blu
Are you pre or post turbo with the EGT Probe?
Old Oct 17, 2011 | 12:41 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
pre turbo using drivers manifold. probe is installed aft of the #8 cylinder where the manifold begins curving upwards towards turbo
Old Oct 17, 2011 | 12:46 AM
MisterCMK's Avatar
MisterCMK
So it gets hot quick with the SRL tune, eh?
Old Oct 17, 2011 | 01:29 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yeah...she gets hot damn quick
on the other hand...she gets up to speed extremely quickly. Wife was griping at me earlier asking me how long I expected the rear tires to last
Old Oct 17, 2011 | 04:51 AM
wulfman's Avatar
wulfman
Tylus the wife's always have something to say about our trucks don't they. Mine is same way .
Old Oct 17, 2011 | 08:08 AM
MisterCMK's Avatar
MisterCMK
After 60 do the EGTs keep climbing? I would be curious to see how they chance after you put exhaust on the truck.
The reason I ask is I have the same setup as you to a T.
Old Oct 17, 2011 | 12:08 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I'm hoping to get 100F drop once I install the downpipe
Muffler is coming out also soon. Going to take it in steps so I have a trend track to see what works and doesnt for dropping EGT
Edit: BTW, I dont go above 60 mph out here. Speed limit is 55 mph and I detest tickets. Truck is kinda obvious when speeding. So won't be able to get that data
Old Oct 17, 2011 | 12:53 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
That's the same thing I see, and I've had the same set-up as you (with the exception of the missing cat) for a year or so. Hitting 1400* for short periods of time isn't a problem, but sustained operation at that temperature is something you'll want to avoid.
Old Oct 17, 2011 | 12:55 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Our high temp is more like 1400..... When I tow, 1000* is pretty normal to see in a very slight incline. BIG hills I've seen 1300 a lot..... but it drops right off quickly when it drops a gear.....After seeing what I've seen since I've had the truck (05), I now seldom even look at EGT's anymore! The truck is smart enough to keep me safe!
Old Oct 17, 2011 | 04:14 PM
bpounds's Avatar
bpounds
That's why you don't tow with those tunes.
With stock tuning, I agree. Them boys ^^^ ain't running stock tunes. About 1300° is all I see with stock tuning and it takes pulling a load on a good hill to see that much. The truck will either downshift, or I will back off a little right around there.
Old Oct 17, 2011 | 06:46 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I do wonder how my tires are affecting temps. I bet stock sizes are slightly lower temps since engine is working a little bit less
I'm not towing or hauling and I'm seeing those numbers
Full tank of diesel
Me, Wife, 4 kids in cab
Stroller in bed
Toolbox is empty until I rekey it
So overall not alot of weight IMO
Old Oct 20, 2011 | 04:00 PM
MisterCMK's Avatar
MisterCMK
I bet they are not affecting it much. A hot tune is going to bring higher EGTs. I am curious how your EGTs drop once you put a different exhaust on the truck.
Like Steve said the 1,400* EGTs for a short burst aren't something to worry too much about.
G707minniemo
May 10, 2008 12:11 PM
Aaron Steinblock
Sep 15, 2007 11:42 PM
sourbeer
Aug 16, 2007 09:15 AM
AnfoBill
Nov 21, 2005 09:55 PM
