Front Hub Bearing Replacement?
Old Oct 16, 2011 | 04:51 PM
polarspeed's Avatar
polarspeed
Hello,
I have just taken my front hubs off and wanted to pop out the cups to replace them. However, before beating on them, I thought that I would check in with you guys to see if there are any tricks. Would it be safer to take them to a machine shop? There is a great shop in town that I trust. I definitely do not want to mess up the hub.
Thanks, Steve
Old Oct 16, 2011 | 08:52 PM
spurredon's Avatar
spurredon
Are you talking about the bearing races? If so, drive them out from the outside with a brass rod and hammer.
Old Oct 16, 2011 | 09:06 PM
polarspeed's Avatar
polarspeed
Yes, the bearing races. Brass rod? Is it the same to install them? Taping around to keep them square? Thanks, Steve
Old Oct 17, 2011 | 10:20 AM
fromnwmt's Avatar
fromnwmt
Always better to use a press to remove & install bearing races BUT i have replaced many with a dead blow hammer n brass rod.... jwj
Old Oct 17, 2011 | 10:42 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Take the old bearing cup and grind about 50 thou off the OD, then use it to drive in the new one. I put the thin edge of the old cup against the thin edge of the new one.
Old Oct 18, 2011 | 12:24 AM
polarspeed's Avatar
polarspeed
Ross, That worked really well. I pounded them out with a punch, then used my grinder to shave off a bit and they went in with a bit of pounding on a plate over the old races. They are now back on the truck. Soon I will have the new steering box in, drag link back on and then back on the road. I hope to drive her some before the rain comes. I don't have wipers yet. Thanks again, Steve
1999-F150
Jun 3, 2018 06:43 PM
got2bjoester
Escape & Escape Hybrid
26
Dec 24, 2015 03:13 PM
scottddove
Aug 12, 2015 12:48 AM
paddler
Aug 12, 2010 02:36 PM
yotazuki
Aug 1, 2009 09:46 AM
