Setting ignition timing
Old Oct 16, 2011 | 04:28 PM
thefordman1992's Avatar
thefordman1992
85 351HO windsor.....wat does the ignition timing need to be set at. engine is stock except for edelbrock carb
Old Oct 16, 2011 | 04:57 PM
Old Hickory's Avatar
Old Hickory
If you have just the carb change and every else is stock, then I would set the timing
at the stock setting. The info should be on the sticker in the engine compatment.
Old Oct 17, 2011 | 08:47 AM
thefordman1992
Thank you. I never knew that was there.
The Terrible Blob
13
Feb 1, 2014 08:00 PM
square-body-lover
Nov 20, 2011 04:52 PM
mantta
Aug 14, 2006 10:12 AM
Fordnite302
Aug 1, 2003 01:38 AM
cdd5599
Oct 22, 2002 04:04 PM
