Steering wheel
Old Oct 16, 2011 | 09:28 AM
2000F250guy's Avatar
2000F250guy
Steering wheel
Im sure the truck could use a alignment, it doesn't pull though. But the problem is the steering wheel is turned so my turn signal doesn't work properly. So can i just pull it off and turn in one/two on the spline? i would just have it aligned but money just got tight for a bit.
Thanks in advance.
Old Oct 18, 2011 | 10:40 PM
crum71's Avatar
crum71
1/8 mile Oval Track
You have to turn the sleeve on the front steering part,cant remember the name of it,but you will see what Im talking about by looking at the front drag link or steering components. You will loosen the nuts on both ends and turn it to what direction that will straighten the wheel. I tried the steering wheel removal thing thinking the same thing,it will not work ! lol plus if you dop this make sure you plug up your horn and airbag before you reinstall the wheel. i failed to do so,and had to do it all again. # 8 or # 9 is the part Im talking about
Old Oct 18, 2011 | 11:26 PM
Bonanza35's Avatar
Bonanza35
Scott has you covered. It has to be done that way to make the mechanical part in the colum work. Chet
Old Oct 18, 2011 | 11:42 PM
PaysonPSD's Avatar
PaysonPSD
Nice diagram Scott.
The adjustment is made on #9. That is the adjustment collar on the drag link. Doesn't have to be turned much. Just turn it an 1/8 turn to determine steering wheel is moving in the right direction. Don't forget to re-tighten the 2 collar holding bolts when done with adjusment.
maverick600
Feb 1, 2014 03:07 PM
duggyb
13
Dec 23, 2013 06:10 PM
scottjbear
Jan 7, 2012 04:29 PM
fredo181
Aug 2, 2009 04:27 PM
earl964
Dec 3, 2007 08:31 PM
