A little rebuild
Old Oct 16, 2011 | 02:13 AM
lucky_thirteen's Avatar
lucky_thirteen
A little rebuild
Bought this thing when I was 18, daily drove it like this for a while.
Broke a bunch of parts on it, and it ended up sitting behind the shop for a bit. Started to rebuild it into more of a wheeler, got cancer, and once again it ended up sitting for a while. Went something like this
Old Oct 16, 2011 | 02:14 AM
lucky_thirteen
Once I had my strength back after chemo, I ended up putting one my Toyota's back together, since it was the closest to being done, and this truck was left, still sitting.
The 'yota
Got a wild hair, and gathered up some bigger parts for the Ford, this is where the build starts to get interesting
lucky_thirteen
Old Oct 16, 2011 | 02:15 AM
lucky_thirteen
Some random bits and pieces
Front tie rods
Rear link mounts, frame side. Lower mounts are Blue Torch Fab pieces, upper mounts are built by me
Built mohawks for the rockwells
Upper link mounts, axle side
Start of the upper link mounts, chassis side
Lower link mounts, axle side
Old Oct 16, 2011 | 02:17 AM
lucky_thirteen
This is the clearance around the front chunk at full bump. I'm going to have to run a two piece front driveshaft to clear the engine block.
Ride height will be a little taller than this
Finally got off my *** and finished the other two wheels for it
Here's the basics of how I recentered them.
Step 1: Probably the most important step. Remove the tire from the rim/break the bead and a put a block in to keep it from reseating/or do like I did and holesaw a hole in the tire. You don't want a tire blowing up on you. Then cut the center out
Step 2: I broke the bead on the trailer tires ( a bottle jack and a heavy truck works quite well for this), and used some prybars to pry one side off the wheel. Cut the center out
Step 3: I put the wheel on the welding table, and used some scrap steel to set the backspace. Take a bunch of measurements to make sure it's centered, and weld away. Reseat the tire, and fill with air
Old Oct 16, 2011 | 02:18 AM
lucky_thirteen
Cut apart some old driveshafts. This is the easiest way I have found to do this.
Grind the weld down
Make two cuts, opposite sides
Cut around the weld, then hammer a chisel into the cuts you made
You'll be left with a pile of drive shaft parts
Old Oct 16, 2011 | 02:19 AM
lucky_thirteen
Old Oct 16, 2011 | 02:23 AM
lucky_thirteen
That's pretty much up to date. Truck is sitting again though. Sold my Yota to a buddy, and am building a cheap(er) wheeler. I changed career paths and have to buy a bunch of tools, so this will be on the back burner for a bit.
Old Oct 16, 2011 | 02:04 PM
whiteisright's Avatar
whiteisright
Awesome work, looks like it'll be a blast
Old Oct 16, 2011 | 03:04 PM
devino246's Avatar
devino246
VERY nice work!
Old Oct 16, 2011 | 03:30 PM
montana_highboy's Avatar
montana_highboy
Awesome fabrication work, stellar, but it's not even remotely a dentside at this point (cab only), perhaps this is more apropos in the 4x4 forum? nice trail rig though.
Old Oct 16, 2011 | 07:25 PM
lucky_thirteen
It's in the offroad section, I was asked to post a build thread here also. It will eventually have all the sheet metal again
Old Feb 7, 2015 | 02:30 AM
lucky_thirteen
Well I ended up selling this thing after it sat for a while. Here's what it looks like after the new owner got it put together
If any of you happen to follow Top Truck Challenge, be sure to vote for this thing
Old Feb 7, 2015 | 12:45 PM
co425's Avatar
co425
That truck is plain awesome. Love the fab work as well. I'm getting there in the proper tool department to do some of the little tricks you do.
JRC99408
51
Mar 15, 2021 08:25 PM
lungerbrothers
1961 - 1963 F100 Unibody
Nov 30, 2017 06:17 AM
lucky_thirteen
Offroad & 4x4
48
Nov 29, 2012 04:52 PM
BrizNasty
24
Nov 24, 2012 06:40 PM
cobra_4
General Automotive Discussion
Sep 18, 2012 06:47 AM
