Help please/ wtf is wrong
Old Oct 15, 2011 | 10:21 PM
Hurricane67's Avatar
Hurricane67
Ok Guys I put my EGR delete kit on as well as my new oil cooler, got everything back in went to start it and no go....(shot it with a little either) it cranked up got to about 150 degrees and died, now it wont crank, bully dog code says Crankshaft position sensor, will this make it not crank at all???? where the hell is this sensor and what do i need to do to get it out, is there in video out there, the video from srmastertech was awsome.. pleas help someone...
Old Oct 15, 2011 | 10:52 PM
BLADE35's Avatar
BLADE35
I bet that Code is just from the engine stall
I bet it got junk in the system from the work anf took out the IPR
Id pull the IPR and check the screen if its pushed or has a hole in it
do you have any gauges
FYI Dont spray the either in it anymore your gona kill an injector or something
Old Oct 15, 2011 | 11:03 PM
Hurricane67
Thanks Benny guess i have to pull the turbo back off???? Is the IPR the one in the back on the high pressure oil pump with the single wire attached???? just un hook the wire and wrench it out?????? if thats it..can it be taken out without removing the turbo??? Thanks for your help
Old Oct 15, 2011 | 11:08 PM
BLADE35's Avatar
BLADE35
Yes its the one under the turbo
some say that they can get them from underneath the truck IDK
What year is the truck???
Old Oct 15, 2011 | 11:09 PM
NewToDiesels's Avatar
NewToDiesels
No
Yes
Yes
Yes
Old Oct 15, 2011 | 11:10 PM
BLADE35's Avatar
BLADE35
if its an 03 its the one closest to the Cab
Old Oct 15, 2011 | 11:16 PM
bismic's Avatar
bismic
The IPR can come out without pulling the turbo (as NewToDiesels answered earlier).
Old Oct 15, 2011 | 11:32 PM
m-chan68's Avatar
m-chan68
Huh??? The IPR valve should have two wires going into the connector, one red wire and one yellow with red stripe coloured wire. If one of them is MIA or shorted to the other one, the engine will NOT fire.
Old Oct 15, 2011 | 11:39 PM
Hurricane67
Its a 2004, and it may have 2 wires all i know is it has alot of heat sheild silver stuff over it with velcro at the end, had to take it off when i pulled the wiring harness....is there any special tools needed for this with the turbo attached???/
Old Oct 15, 2011 | 11:47 PM
m-chan68's Avatar
m-chan68
An IPR valve socket. But in absence of it, you can make your own, by buying the correct size/depth socket and cutting out a slot to clear the connector.
Old Oct 16, 2011 | 02:26 AM
Hurricane67
Well Guys, I took the IPR valve out and had a look see, the thing was completly stopped up, I removed the green o-ring and popped the screen off and cleaned the crap out of it, will buy a new one Monday, put it back in, and the truck fired right up, what does this valve do???? IPR (internal pressure regulator) is this what ipr means??? I also added a coolant filter system, with screw on filters, but I watched the video on sinister diesel on how they plumbed it, I went into the heater hose(as did they) and from there to the degas bottle, but the heater hose line has a valve in line also, when you flip the heat on the dash the valve opens but if im running the a/c is the water still going to circulate thru the filter????? but thanks for all of your help, couldnt have done it without yall, Thanks Benny.....
Old Oct 16, 2011 | 04:46 AM
wulfman's Avatar
wulfman
Did you plumb the tee before or after the valve it needs to be before, front of motor side.
Old Oct 16, 2011 | 07:07 AM
bismic's Avatar
bismic
IPR - Injection pressure regulator - it controls the high pressure oil pressure to the injectors - based on the reading from the ICP sensor, etc.
Old Oct 16, 2011 | 07:20 AM
cheezit's Avatar
cheezit
ipr is a metered oil bleed off from the high pressure oil pump. it allows the excess pressure to bleed of and return back to the sump (oil pan).
the icp is the result of the pressure built by the pump minus the pumps bleed off by duty cycling the ipr, that duty cycle is controlled by the pcm.
Old Oct 16, 2011 | 12:22 PM
NewToDiesels
cheezit thanks for the explanation... I have been wondering how the pressure was regulated by the IPR since I replaced my HPOP a little while back. I knew what it did, but didn't quite get the how. I would rep you, but the mean program coding won't let me. Apparently, I'm being regulated...
BTW - Mr Hurricane - glad you got her running! Awesome job. Thanks for posting the fix.
