Brake Booster help/suggestions
Old Oct 15, 2011 | 07:40 PM
johnson2007's Avatar
johnson2007
I have a 1979 F-150 4wd with 400 and cruise. I am looking to replace my power brake booster. The number on my brake pedal is D7TA MA. My pickup's VIN is F14SRDG3550. I have been reading about the dual diaphragm booster upgrade from an F-350. Is this a good upgrade? Should I just save the money and do a hydroboost upgrade later? If the F-350 booster provides a lot better braking the F-150 booster, I would definitely be interested. I think I would need the 50-3311 booster by A1Cardone. Can anyone confirm if this is correct for me? Just looking for some opinions. Thanks guys!
Old Oct 15, 2011 | 09:25 PM
mark a.'s Avatar
mark a.
I put a F-350 dual diaphragm booster in my '79 F-250, to be honest I didn't really notice much of a difference even with it's bigger master cylinder bore. I'd say if your old booster is junk and your master is leaking go for it, but to just change it thinking it's going to make some huge difference then I'd pass. If you order one get it for a '79 F-350 for your truck. I did have to modify the mounting brackets, change the dust shield back from the old one and move the lines to the other side of the master cylinder but it was a easy swap.
Old Oct 15, 2011 | 09:42 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by mark a.
to be honest I didn't really notice much of a difference. but to just change it thinking it's going to make some huge difference then I'd pass.
That's my personal experience as well, it wasn't the quantum leap in braking power i thought it would be, if you're doing the hydroboost upgrade in the near future anyways, i'd just skip the dual diaphragm booster "upgrade", my 2 cents.
Old Oct 15, 2011 | 09:48 PM
CaptainIPSC's Avatar
CaptainIPSC
Hydroboost and be done!
Old Oct 16, 2011 | 10:21 AM
akforceten's Avatar
akforceten
Yes I agree with Captain IPSC , go Hydroboost an be done with it . That's what I'm doing .
I'm using one from a 2001 ford superduty.
KG Excursion
18
May 18, 2017 08:29 PM
bootsmagee84
Nov 1, 2016 10:16 AM
Jrobole
Jun 3, 2016 07:49 PM
junkyardjeff
Jul 7, 2008 08:36 PM
2classics
16
Apr 3, 2006 12:41 PM
