Yup, looks like you got it. Besides the polishing issue with the aluminums it all comes down to wear. Put 2 tires with different wear patterns on the rear and you run the risk of not evenly distributing the weight across the 2 tires. I have seen it where one tire is not even touching the ground due to breaking up the pairs. Not much good there...
Due to crowns in the highway design, etc.
And my alignment being perfect (??).
Sound like I need to break the front tires from the RIM and flip it (inside / out) somewhere about mid life (or shortly before).
Is this your exprience also PowerStrokeHD ??
It really is about the only option that you have to correct the outer edge wear problem. Even changing the direction of the tire on the rim will only be a partial solution to your problem.
Even though you are within the alignment specs, I would expect a good alignment shop to be able to make an adjustment to the camber to help with the problem. On some vehicles you have to venture "outside the box" sometimes, but most shops can't think that far for themselves.
How true!!!
Had an issue with another vehicle years ago. Dealer Alingment said, OK, OK, OK etc, always tire wear on same spot.
A speciality shop, said, no big deal, we can do X,Y,Z and fix it....
and they did....
Yes sir... I'd say that just about every Ford DRW I have seen, including my own '00 F-350 DRW, had poor front tire wear. Just as you say, the outside takes the brunt of the wear.
Breaking them down and flipping them mid life may just help extend the life some, although I have never done it my self.
