Water Pump Question
Old Oct 15, 2011 | 06:54 PM
davewave649's Avatar
davewave649
Water Pump Question
Will a waterpump for a 1979 302 work on a 1977 302?
Old Oct 15, 2011 | 09:05 PM
xlt4wd90's Avatar
xlt4wd90
I think they should be both V-belt driven, so I don't see any reason why they should not exchange. Try looking up the replacements on an online parts catalog, and see if they refer to the same replacement part.
Old Oct 21, 2011 | 08:57 PM
baddad457's Avatar
baddad457
Yes. The only 79's that had a different pump were the Mustangs, these had the first reverse rotation pumps if I'm not mistaken. Now, if you want a high volume pump, get one for a police or taxi application or one listed for "extra cooling"
Old Oct 23, 2011 | 02:52 AM
xlt4wd90's Avatar
xlt4wd90
The water pumps that turned in reverse were on the engines with the single serpentine belt.
There was a recent thread about this, but I can't seem to find it. In addition to the impeller designed for one direction or the other, the mounting face and the inlet ports in the front cover have to match the flow direction.
But as I said, if both pumps were driven by V-belts, they should exchange.
Old Oct 23, 2011 | 11:23 AM
baddad457's Avatar
baddad457
The 79-85 reverse pumps are exactly like the std rotation pumps, with the exception of the impeller. They use the std rotation timing covers. Beginning with the 86 model year, Ford revised the timing cover and the pump body for the reverse rotation setup to improve the flow. These were used on the Mustangs, pickups and vans only.
silar
Sep 16, 2014 01:27 PM
TheJunkMan
13
Dec 11, 2010 04:41 PM
4x4xTOR
Mar 6, 2008 09:14 PM
rts9364
Dec 30, 2006 07:21 PM
likethefords
Apr 12, 2006 11:03 PM
