Sponsored by: Auxito
Anyone Know??
Old Oct 15, 2011 | 05:44 PM
rdw516's Avatar
rdw516
Question Anyone Know??
2001 F150 Lariat 4.6
Will not start....sometimes
It does not matter when or where, this P/U will not start sometimes. Whether the engine is hot or cold, recently run or been sitting, it does not matter. There are NO CODES in the OBD diagnostics. When it does it their is ZIP fuel pressure and the fuel pump does not run. I have replaced both the fuel pump relay and the PCM relay and even switched them out with the old ones. It never stops, spits or sputters when going down the road or when the engine is running. Just when starting does this occur. I have done nothing but let it sit for a few hours and gone back and it starts like nothing was ever wrong. I am getting ready to replace the fuel pump...maybe a dead spot on the armature?? Who knows. This intermittant problem has me baffled.....
Old Oct 15, 2011 | 06:56 PM
IndySilverAnny's Avatar
IndySilverAnny
Loose connection? Rusty ground? Bad ignition switch?
When you turn the key 1/2 way, do you hear the pump prime? Does the truck turn over at all?
Old Oct 15, 2011 | 07:07 PM
kbsupercrew's Avatar
kbsupercrew
If you already tried your spare key ,Id say its pump time
Old Oct 15, 2011 | 07:52 PM
rdw516's Avatar
rdw516
Motor spins over like a **** on a...well you know.
Old Oct 15, 2011 | 07:59 PM
kbsupercrew
The microchip in the key has been known to fail causing this issue
Old Oct 15, 2011 | 08:21 PM
rdw516's Avatar
rdw516
This occurs with both keys
Old Oct 15, 2011 | 09:24 PM
kbsupercrew
sounds like a bad pump
Old Oct 15, 2011 | 09:55 PM
Bluegrass 7's Avatar
Bluegrass 7
If the pump does not run, the motor won't start.
Access the leads to the pump for voltage monitor and try the ignition to the run position a number of times to be sure your not missing it.
If the voltage is there and the pump doesnot run, you know what you have to do.
You have to test, and not jump to this and that, hopeing to get lucky.
Good luck.
Hasbro61
Mar 5, 2019 06:49 PM
xfrog
Dec 3, 2014 07:56 PM
hedhntr
1983 - 2012 Ranger & B-Series
13
Nov 9, 2008 10:53 PM
barndude
Electrical Systems/Wiring
Nov 6, 2004 09:34 AM
treblehook
Oct 1, 2003 10:11 PM
