Pulled the engine, need some advice...
Old Oct 28, 2011 | 01:36 PM
JLaw92's Avatar
JLaw92
Thanks for the information, I planned on just getting ones out of a junkyard to play around with but when I go to get ones for the engine I'm building then I'll buy new ones. I got another question that may not make any sense but I've wondered it. Could I use chevy rockers with a larger cam? or would that push the valves to far down and hit the piston?
Old Oct 28, 2011 | 02:18 PM
F-250 restorer's Avatar
F-250 restorer
I don't think that would be an issue with a 300. Most pistons are dish. Of course it is always best to check clearance. I used 1.7 roller bbc rockers with cam that gave me .450" lift, thereby producing, IIRC, .483 lift. I guess it was when I sucked a valve my opinion of the c. rockers changed (unbelievably, the valve just hung there, without dropping into the chamber, even though it happened at freeway speed), but then I had a lot going on with my v.geometry: longer valves, Isky double springs with 134 lbs seat pressure, milled head, longer p.rods too. Adapt a carpenters saying when building an engine: "Measure twice, install once."
There are cams out there to give you any lift you want, or you can have one custom ground. Make a plan, with a goal in mind, and stick to it, using your goal to determine what parts you buy. And keep ego out of the equation, lol.
Old Oct 28, 2011 | 04:19 PM
Davidwent's Avatar
Davidwent
ALWAYS replaced: pistons, rings, bearings, cam, lifters, oil pump, wtr pump, p.rods and rockers.
Hey F-250, when you mention pistons, are rods and wrist pins included or should they be ok to re-use?
TIA
David
Old Oct 28, 2011 | 06:56 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
No worries to reuse rods if they can be machined true. Most pistons come with wrist pins.
Old Oct 28, 2011 | 06:58 PM
Davidwent's Avatar
Davidwent
Gotcha...Thanks!
sherLocke9
Dec 18, 2010 10:24 AM
Waff78
1997 - 2003 F150
May 25, 2009 11:52 PM
broncoray
Bronco II
Jul 26, 2004 06:34 PM
Hammered Wombat
Dec 14, 2003 07:13 AM
TonyG
22
Oct 23, 2001 12:27 AM
