Is there a better plug/different heat range spark plug??
Old 10-14-2011, 07:51 PM
mattsautobody442's Avatar
mattsautobody442
mattsautobody442 is offline
I had a honda civic that used to list a "highway" use plug for people who did extensive highway driving that was different from the standard plug for a stock car. is the same true for the 5.4l 3v???
Old 10-14-2011, 08:46 PM
Coskid's Avatar
Coskid
Coskid is offline
Yes the better plug is the Motorcraft plug designed for these engines. Many have tried other plugs and many have come back after poor performance.
Old 10-15-2011, 03:24 PM
Palvin1951's Avatar
Palvin1951
Palvin1951 is offline
Just did the plugs at 211k on my 04 and went with the one piece Champion 7989. Truck is running just fine after 2k on the new plugs.
Old 10-15-2011, 06:19 PM
Coskid's Avatar
Coskid
Coskid is offline
Most of the guys said that after about 10k the champion plugs started causing problems. Now not everyone has this issue but many of reported it. I still see it just best to stick to OEM plugs for engines even my wife's jeep rejected the plugs I put in that were not OEM.
Old 10-15-2011, 09:12 PM
hcbph's Avatar
hcbph
hcbph is offline
Plugs
I've been running Champions in mine since last spring. No problems, no issues and I'm actually getting a little better mileage out of it than with the OEM plugs.
Old 10-16-2011, 09:22 AM
HYPO's Avatar
HYPO
HYPO is offline
I now have 28,000 mi. on my Champions and have had zero problems. Earlier on (4 years ago) there were some problems reported, but I am not seeing those problems being reported of late. At any rate, Champions are one-piece(or welded, whatever) and can easily be removed without breakage. This fact alone was enough impetus for me to try them. Really glad I did.
HYPO
Old 10-16-2011, 10:47 AM
Palvin1951's Avatar
Palvin1951
Thumbs up
HYPO
Glad to hear it. I will let you all know if I have differing results. Thanks for the feedback. (i just love smiles)
Old 10-16-2011, 02:16 PM
Coskid's Avatar
Coskid
Coskid is offline
Glad to hear you aren't having any problems better then what most reported as short as earlier this year but the breakage issue is easily fixed with a small amount of anti seize.
Also better mileage is common after replacing plugs as the engine is firing better I would not say this is because of the champions but this is better news for Champions then in the recent past but I would still not use anything but OEM plugs.
Dresser77502
2004 - 2008 F150
07-29-2020 06:09 PM
hodges710
1997-2006 Expedition & Navigator
07-03-2012 06:55 PM
pjw73nh
17
09-02-2011 05:17 AM
tatonka
08-13-2006 05:39 PM
Super-Dayv
1978 - 1996 Big Bronco
12-07-2005 05:56 PM
Quick Reply: Is there a better plug/different heat range spark plug??
