Vibration while slowing down
Old Oct 14, 2011 | 02:40 PM
hawgystyle's Avatar
hawgystyle
My 93 F-250 w/ 7.3L N/A E4OD last night started to vibrate while slowing down. But there is no vibration when I give it a little bit of gas or foot to the floor but as soon as I let off the pedal the truck starts vibrating only when moving at any speed. No vibration when standing still idling, or reving when not moving. I want to think it could be the rear end. Any ideas before I tear the whole thing apart?
Old Oct 14, 2011 | 03:08 PM
andym's Avatar
andym
It could be torque converter shudder. When was the last fluid change?
Old Oct 14, 2011 | 04:19 PM
hawgystyle's Avatar
hawgystyle
The Fluid is probably in the 60,000 mile range. but i went ahead and put the truck on the lift and one of my U-Joints was very loose. Just picked another one up and Im gonna install it and hope thats the problem
Old Oct 14, 2011 | 05:52 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
them 36" super swampers kinda would have a tendency to do that to U-joints.
keep us posted.
my thoughts jumped right to andym's reading your post too.
fyi,depending on trans temps,your about twice overdue for a trans fluid change (if using dino juice still.)
Old Oct 14, 2011 | 07:11 PM
octaneforce's Avatar
octaneforce
the u joint was probably the issue. my truck did the exact same thing, and i realized that my driveshaft had loosened from the pumpkin
andym's Avatar
andym
Yes, change your tranny fluid ASAP. You are way overdue.
Old Oct 14, 2011 | 11:10 PM
hawgystyle's Avatar
hawgystyle
Well I've never had this problem before. I cannot get the U-joint off. I took the four bolts off the pumpkin side and took the shaft out of the transmission and I put the drive shaft into the vice and I cant get it to budge no matter how hard I hit it. Gonna break out the torch tomorrow to heat it up and try again.
Transmission.... trying to fill up 17 quarts gets a little expensive sometimes. (Just dropping the pan, ATS Deep Pan) I was told to change the transmission fluid every 80K miles. How often am I supposed to change it?
And im not running the swampers anymore, got just a little too expensive and im running on a set or tractor trailer tires.
Old Oct 14, 2011 | 11:46 PM
FORDF250HDXLT
as general rule; 15k-20k miles towing/off road/working her good,30k miles normal driving.
true,it's not cheap to flush a trans every 30k miles max,but sure is cheaper than replacing it.
Mercon or Mercon 5 only.
Old Oct 15, 2011 | 09:59 AM
hawgystyle's Avatar
hawgystyle
Well thats good to know, never listening to my dad again on when to change transmission fluid.
Old Oct 15, 2011 | 11:14 AM
bafm's Avatar
bafm
Try pressing it out with your vice. Put a socket that's barely smaller than the yoke ID on the u-joint cap on one side with a socket thats larger than the yoke ID aginst the outside of the opposite side.
Old Oct 15, 2011 | 01:56 PM
andym's Avatar
andym
You can also rent a ball joint press from Autozone. The tool doubles as a u-joint press. If you can't get it out with that, then someone tacked it in place.
Old Oct 16, 2011 | 03:08 PM
hawgystyle's Avatar
hawgystyle
I got it out and replaced. I used the socket idea plus thje heat from the torch and it popped right out. New U-joint is in and the vibration is gone. Transmission fluid was changed as well.
hawgystyle's Avatar
hawgystyle
Thank you everyone for your help
Old Oct 16, 2011 | 03:23 PM
rikard's Avatar
rikard
My Dad used to change the tranny fluid on his 83 AOD after hauling his trailer to Fla from Maine every Oct. Truck and tranny lasted 218k miles.
regards
rikard
Old Oct 16, 2011 | 09:21 PM
hawgystyle's Avatar
hawgystyle
305K miles and still running strong. Transmissions is around 150K by now I think
rowdyjoe
2009 - 2014 F150
Nov 21, 2017 08:24 AM
Mazman
Feb 18, 2015 05:24 PM
mel63
Sep 13, 2007 07:45 PM
djmasemore
1997 - 2003 F150
Jan 3, 2007 12:35 PM
bandit990
Feb 24, 2006 10:17 PM
