Vibration when taking off
Old Feb 23, 2006 | 11:58 AM
bandit990's Avatar
bandit990
I have a 1990 ford f150 4x4 with automatic transmission, lately when i am at a complete stop and accelerate i get this vibration that lasts for about a second. I took it to a local car shop and the mechanic said it could be the driveshaft sticking to the transmission and not sliding as it should, so i took off the driveshaft regreased it and stuck it back in there but im still getting the same vibration. you can't feel it when your moving and if not at a complete stop you dont feel it.
Any Idea's what it could be?
Old Feb 23, 2006 | 02:13 PM
53fatfndr's Avatar
53fatfndr
I'm wondering if it might be torque converter shutter. When was the last time you changed your tranny fluid?
Old Feb 23, 2006 | 02:32 PM
bandit990's Avatar
bandit990
im pretty sure they changed it when they changed my oil, that was less than a month ago when i bought the truck
Old Feb 23, 2006 | 03:07 PM
53fatfndr's Avatar
53fatfndr
I wouldn't be sure about anything. Check the fluid by pulling out the dipstick and looking at it. If it smells burned or is brownish, it's time to change it. The fluid should be a bright red, no discoloration.
Your problem may not even be torque converter shutter, but this is just a possibility.
Old Feb 23, 2006 | 07:15 PM
William's Avatar
William
Springs (loose/broken), shackel bushings, bent or dented drive shaft?
Old Feb 24, 2006 | 06:27 AM
stuart1's Avatar
stuart1
Have a close look at the front Ujoint.
Old Feb 24, 2006 | 11:40 AM
jim henderson's Avatar
jim henderson
Torque shudder usually only happens when the converter clutch locks up. From what I recall reading, this is only supposed to happen in steady cruise mode. The converter is not supposed to be locked up under acceleration. I am no tranny expert but I believe this is correct.
There was a TSB regarding lubricating the slip shaft on the tail of the tranny with I think a Silicone grease.
Like the other guys said you also need to check other suspension parts. Do you have the truck raised up? This often causes problems with the U joints. Also check the center U joint carrier to make sure it hasn't come loose.
Good Luck,
Jim Henderson
Old Feb 24, 2006 | 10:17 PM
witdog2020's Avatar
witdog2020
Rear brake maybe?
I would guess u-joint or rear brake sticking, But if they just changed the Tranny fluid, I would'nt rule out a slightly different fluid, if mixed it could cause a temp shudder in converter.
