1978 - 1996 Big Bronco
front springs
Old Apr 9, 2003 | 02:27 AM
ba 302's Avatar
ba 302
front springs
will front springs off a f150 or 250 fit on a bronco?
Old Apr 9, 2003 | 02:33 AM
greystreak92's Avatar
greystreak92
front springs
As long as they are 4WD springs the F-150 and Bronco shared almost every suspension component to the best of my knowledge. I could be mistaken but I would imagine that the 2WD version of the F-series may have had lighter duty springs at least in the front. (Less unsprung weight on the Twin I-Beam than on the Twin Traction Beam).
Old Apr 9, 2003 | 03:05 AM
ba 302's Avatar
ba 302
front springs
thanks for the reply the reason I asked is because a friend of mine has 15'' springs on the front of his 1984 f150 and it looks like he has a lift but this is just from the factory and the factory springs on my bronco are just 11'' so I figure if I can find some taller springs it will give me a bit of lift. what do you think
Old Apr 10, 2003 | 12:08 PM
greystreak92
front springs
Sounds like a reasonable concept. Will it "level out" the ride or are you going to do something with the rear as well?
Old Apr 10, 2003 | 01:52 PM
ba 302's Avatar
ba 302
front springs
mostlikey put blocks or add a leaf not sure what I'm going to do yet still looking for the taller springs a my local pick a part.
Old Apr 10, 2003 | 03:57 PM
greystreak92
front springs
Add-a-leafs defintately. Won't crush and far less likely to be "spit out" from between the axle and springs.
Whitey Ford
Nov 16, 2016 04:43 PM
Outlaw56
15
Sep 10, 2013 03:12 PM
eds94aero
Aerostar
13
Jun 9, 2011 10:19 AM
mrwrench
34
Feb 16, 2009 03:37 PM
blatherskite
Dec 17, 2003 09:28 PM
