The Beast
Old Oct 14, 2011 | 01:03 PM
Thinroyy's Avatar
Thinroyy
The Beast
Ok I have a 2000 Ford Excursion, Limited, with the 6.8L V10, and I want to personalize it a bit. I was thinking about putting a 3-inch body lift on it, but before I do that I need to know a few things first...
1) How much will it cost to raise it, if i take it to someone to install it (just need a rough estimate)
2) I have a 2004 Homestead Rv, that weighs around 7,200lbs...willl the body lift effect my towing, and if so what can I do to fix it?
thanks,
Thinroyy
Old Oct 14, 2011 | 03:03 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Do a search, you'll find the V/B or V/F code spring swap will get you what you need.
Old Oct 14, 2011 | 06:17 PM
Fishing_Uncle's Avatar
Fishing_Uncle
Personally I have never like body lifts, especially when you are talking about towing something.
Look into the spring swap like Toreador_Diesel mentioned, tons of good info on here. I have been looking over all the posts as well.
Old Oct 14, 2011 | 10:07 PM
wpnaes's Avatar
wpnaes
Agree, lift the suspension, much safer and with the V/B swap, you'll improve your towing handling.
Old Oct 15, 2011 | 07:26 AM
locknload223's Avatar
locknload223
A body lift is only going to raise you center of gravity making your already soft and mushy stock suspension MORE unstable towing or otherwise. As others have stated, swap the springs.
Old Oct 15, 2011 | 11:17 AM
Thinroyy's Avatar
Thinroyy
So If I do swap out the springs, would I be able to do it on my own or would i have to take it in to do it, and would i still be able to pull my trailer?
Old Oct 15, 2011 | 11:58 AM
wpnaes's Avatar
wpnaes
Click on 'search', then 'advanced search', type in 'V/B spring swap' in keywords, scroll down and highlight in the box "search in Forum" to 'Excursion, King of the SUV's'. Click on Search now. Spend the next couple of hours reading many interesting posts. Here's a sample:
https://www.ford-trucks.com/forums/1...b-springs.html
Old Oct 15, 2011 | 09:07 PM
locknload223
That really depends on your mechanical ability. It's not that bad of a job though. And yes, you can still tow with that spring swap... and then some.
CAP'N CRASH
Offroad & 4x4
Nov 5, 2007 02:17 AM
Desert Dog
Bronco II
13
Feb 14, 2006 07:47 PM
code3k9
May 20, 2003 11:59 AM
Tex311
Bronco II
Apr 10, 2003 03:50 AM
rabidsnowmobiler
Aug 21, 2002 08:06 PM
