69 dash light problem
Old Oct 13, 2011 | 09:48 PM
lil neet's Avatar
lil neet
Another obnoxious elect question lol
I recently painted my grill and changed wire looms for headlight and turn signals with much better non cracked wires .I had to ground the grill seperate with a small wire attached to the grill to get the turn indicator on the right to work but I figured it was cause the grille was painted and not making as good of ground .So all the headlights and turns sig work fine now but now the dash lights are not working .I did move the volt regulator too from rad support to inner fender not sure if that would matter .I cannot figure out why the dash worked fine before and now they will not light up or an other interior guage lights .The strange thing is the high beam blue ind light works in gauges and interior light works still off the headlight switch .
Old Oct 13, 2011 | 09:53 PM
tpdaniels's Avatar
tpdaniels
This may not be the correct answer, but I can tell you from experience you had better have the voltage regulator grounded very good or you will have all kinds of electrical problems.
Old Oct 13, 2011 | 10:22 PM
lil neet's Avatar
lil neet
yeah I hear you on that one but that is grounded well .I just am wondering if it maybe if it needs to be replaced .Could this be it maybe ?
Old Oct 14, 2011 | 09:26 PM
dangerous12265's Avatar
dangerous12265
it sounds like a grounding problem in the dash look behind the dash and chk all grounds make sure there clean then go under the hood do the same and i agree with the other guy make sure the regulator has a clean ground
Old Oct 14, 2011 | 11:29 PM
lil neet's Avatar
lil neet
would the ground behind the dash just go bad and where is the ground usually at back there ?
Old Oct 15, 2011 | 03:11 PM
dangerous12265
it should be screwed into the steering column brace its either loose or maybe rusted
Old Oct 15, 2011 | 04:20 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Make sure you have a good ground wire from engine to firewall. Lack of this will also give you some strange problems.
jschluter
Jan 4, 2012 09:26 PM
tbutt130
Mar 23, 2009 09:43 PM
BlueAngel69
Oct 30, 2003 01:04 PM
bremen242
Oct 5, 2003 09:51 PM
jrhix
Aug 6, 2003 04:35 PM
