inline 6 to 351m???
Old Oct 13, 2011 | 09:00 PM
Fordman_95's Avatar
Fordman_95
inline 6 to 351m???
I was thinking about buying a inline 6 truck thats a 78 and was wondering how hard and what i would need to put in a 79 351m?
Old Oct 13, 2011 | 11:18 PM
mustang81's Avatar
mustang81
not the same tranny for sure. 351m,400,429 and 460 share the same bellhousing bolt patern.
Old Oct 14, 2011 | 07:14 AM
BrutalBronco's Avatar
BrutalBronco
300 to 351M/400
If I'm not mistaken, the motor mount perches (that attach to frame) are different also, and would require different ones for a 302/351w swap, however the bellhousing would work for either of these, or if you're lucky to find a 351c, even a 2v headed one, would bolt to the tranny. On the plus side, a 351c is going to weigh less than the 351m/400, or you could investigate a clevor swap. Once that problem is solved(whatever you finally decide) the next thing would be to make sure your radiator is keeping the larger displacement engine cool.
Old Oct 16, 2011 | 12:12 PM
Fordman_95's Avatar
Fordman_95
what engines will bolt up to the transmission with the same bell housing?
Old Oct 16, 2011 | 03:39 PM
mustang81's Avatar
mustang81
289,302,351w,351c.
Old Oct 16, 2011 | 06:08 PM
85e150's Avatar
85e150
The six makes almost as much power as a stock 351m, so you would be going through a lot of effort for not much gain.
A massaged 351w would be worth the effort imo.
Old Oct 17, 2011 | 10:59 PM
Oldrusty77's Avatar
Oldrusty77
I'd keep the 6 personally and beef it up.The 300 is a very good engine.
Old Oct 18, 2011 | 04:38 PM
Fordman_95's Avatar
Fordman_95
i can get a 351w from a friend for cheap has been sitting in the corner for a year now.
64custom
Feb 26, 2014 09:45 PM
'77hiboy
Jun 27, 2008 07:22 PM
bronc84
1978 - 1996 Big Bronco
Feb 23, 2004 05:08 PM
79_ford_400_guy
Oct 24, 2003 12:30 PM
bpowell
Jan 13, 2003 03:14 PM
