GPR LED Light
Old Mar 15, 2012 | 04:17 PM
danskool's Avatar
danskool
Go Bills !
Originally Posted by Backdraft-14
Update: Tested the the blue wire that is fused and it is reading .75 volts Key off and 9.18 volts KOEO, the wire was not connected to the relay during testing. Is this wire supposed to have voltage with it not connected?
Another test hooked up the power wire and the 2 small terminal wires hooked up the LED wire KOEO no light, tried grounding the relay to click over nothing.
Any suggestions?
You have it, One wire of the LED goes to the big stud on the GPR that has no 12v when the key is off. Big Terminal to ground reading (either chasis or - battery) The other LED wire goes to ground terminal. (either chasis or -battery). ?????????? I wouldn't even touch or meter from either of these smaller wires on the GPR for this project.
Of course you want to use a inline fuse 1 amp fuse will do. On the wire from the GPR to the LED. as close as you can to the GPR.
Backdraft-14's Avatar
Backdraft-14
I had the led wire on the large terminal with the blue fused (OEM wire that turns red in the wire loom) it was keeping the LED on constantly since the OEM blue fused wire has 9.18 V going through it with the KOEO.
So the relay is not sending power to the GP because of the blue fused wire is feeding the relay with 9.18 V and the constant hot feeding 11.86 V.
I believe I have a bigger issue and probably should start a new thread.
Old Mar 15, 2012 | 05:47 PM
Backdraft-14
Update: The blue fused OEM wire has voltage when KOEO, (tested my neighbors truck same truck as mine) what I have come up with was my AIH delete. I made the 470 ohm resistor grounded to the block but it was allowing 2.75 volts enough to constantly illuminate the LED for the GPR.
So thats good news. But now I have to figure out the AIH delete. As for the GPR led it must be to warm here in southern CA because the GPR wont kick over unless I ground the small terminal in which the GP's heat up and the light comes on. Will have to try it early in the morning to see if it is cold enough for them. (Probably not)
Old Nov 1, 2012 | 02:46 PM
koski19's Avatar
koski19
After reading this post I installed the LED light mod and tested it. Works great. Now I have a question.
When should the truck be started? When the "Wait to Start" lamp turns off or when the LED light turns off?
Thanks
Jeff
Old Nov 1, 2012 | 03:13 PM
nlemerise's Avatar
nlemerise
Thanks
Jeff
When the LED turns off start the truck...the WTS light tells you nothing.
Old Nov 1, 2012 | 04:31 PM
timmyboy76's Avatar
timmyboy76
a voltmeter gauge would collaborate with what Neal just said. With light on..(led), the volts are around 11-ish, once lights' off, needle moves to 13+volts. You want the juice to fire ur motor, and batteries last longer
Old Nov 1, 2012 | 04:55 PM
koski19's Avatar
koski19
Thanks for your replies and answering my question
jeff
Old Nov 1, 2012 | 05:00 PM
KelVarnson's Avatar
KelVarnson
The only thing I would add to this thread is that you don't need big wire at all. 22 or 24 gauge is more than enough, any smaller and it gets harder to work with. LED's only pull 20 or 30 milliamps, typically.
Old Nov 1, 2012 | 10:05 PM
MTDewX's Avatar
MTDewX
I am curious where you guys get the 1 amp fuse. sounds funny and I laugh at my self too. but I can't seem to find them. been to local auto stores and nothing.
Old Nov 1, 2012 | 10:09 PM
KelVarnson's Avatar
KelVarnson
Radio Shack will have inline fuse holders, and fuses to go in them. You can either get the 3AG size (physical size), or the 5 x 20 mm size, which is about the same diameter, but shorter. Make sure you get the right size holder for the fuse.
Old Nov 1, 2012 | 11:00 PM
SpringerPop's Avatar
SpringerPop
Search eBay for "3ag-1".
Lots and LOTS of choices there.
Pop
Old Nov 1, 2012 | 11:10 PM
schlepprock250's Avatar
schlepprock250
I got a 12v led from Radio Shack,they also had these nifty little chrome holders too..
Old Nov 2, 2012 | 08:02 AM
  #28
AzPete's Avatar
AzPete
Has anyone tried to re-wired the wait to start light direct to the GPR......
Someone tell me where I can cut that light out of the system and re-wire it....
Would it effect the check engine light?
Old Nov 2, 2012 | 01:18 PM
  #29
SpringerPop
It has occurred to me to do just that, and I looked at the circuit board on the back of the instrument panel to see what's necessary. As I recall, it would be very simple by cutting a couple of copper traces and tacking in a couple of wires.
This is necessary because one side of the WTS light is always on +12 volts and is awaiting a ground from the PCM, whereas it needs to be modified to always being on ground looking for a +12 volt input.
Ignore the blue tape arrow in the photo below (it's for another project). The WTS is the middle of the left-most three sockets.
Pop
Old Nov 2, 2012 | 01:25 PM
  #30
KelVarnson's Avatar
KelVarnson
If someone was feeling adventurous and wanted to convert a positive signal (from the GPR) to a pull-down-to-ground signal, that can be accomplished with a single NPN transistor and a resistor, both available from Radio Shack, and I would be happy to describe how to do it.
Going a little further, if the signal from the PCM is open-collector (or open-drain), the transistor could just be thrown in parallel with the PCM and both functions would be "ORed" together. ...but I don't know whether the PCM meets that criteria.
