crown vic rear axle question
I've swapped the front now I'm changing the rear end to match from a crown vic. I tried searching again for what year rear I needed to match in width but couldn't find it this time. I plan on using the factory steel wheels. The front is 2005 and plan on a 95 rear, will this fit? Thanks.
Originally Posted by rustywheels
..than the 1973/79 width.
1973/78 LTD's are not the same cars as the 1977/79 LTD II .. FoMoCo's idiotic and confusing name that replaced Torino.
Same basic "Panther" platform under the skin: 1979/81 LTD / 1979/2010 Mercury Grand Marquis / 1980/2008 Lincoln Town Car / 1982/2011 Crown Victoria.
FoMoCo changed LTD to Crown Victoria in 1982, because...
1983/86 LTD/Mercury Marquis are mid-sized "Fox" bodied cars.
I know this is an old thread... but I'm having a mental debate. I've got a '57 and have access to the state auction. They regularly sell old police vics. I want the front end and the motor for sure.
I'm debating on also keeping the AOD trans and the rear. The rear mostly to address the track issues from using the cv front end and the stock rear end.
Since it's been a few years... are you running the CVs rear? any real issues with it?
The Explorer rear is even more narrow than stock - 59.5" vs stock F100 - 61.25" If the idea is to get the rear end closer to the same width as the CV front, this is kinda going backwards. Although, limited slip, disc brakes, 31 spline axles would be nice......
Don Vito
07-04-2016 06:45 PM
hotrod66_57
36
05-26-2009 12:26 PM
chris eck
02-26-2008 05:35 PM
