e250 speedometer down
Old Oct 13, 2011 | 05:52 AM
li_mustang's Avatar
li_mustang
hi i got a 99 e250 5.4 automatic,this morning the speedo didnt move at all.the vss was change 3 week ago. hard shift from 1 to 2,any idea.
sorry for my bad english im from montreal. im a fte fan check new post every morning, also i have a 02 mustang gt and check engine come on and i read po340 that its a code for cam sensor,i change it ,fix nothing,sometime it hard to start on first time and make backfire,second time start well any idea on that too.
ty in advance
Old Oct 13, 2011 | 10:51 AM
PStruwing's Avatar
PStruwing
Check your battery voltage, your talking a few different things here so start with the basics, the seasons are changing and it is colder in the mornings so check your battery.
As for the bad English, I dont expect that from someone from Montreal. Valcourt, where I spent a lot of time I expect bad English.
Vive Les Habitants
Old Oct 13, 2011 | 04:33 PM
li_mustang's Avatar
li_mustang
i was in mirabel 60 km north of montreal exactly. this afternoon my speedometer start to work but when i start from 0 it going up only when i go like 20 km hrs after look ok and my battery was brand new, full charge.thanks for the reply.
Old Oct 14, 2011 | 06:02 AM
JWA's Avatar
JWA
We'll forgive your English if you forgive our French? LOL
Best thing about some vehicle issues is they're easily understood as long as the description are close.
Hope you get this resolved!
Old Nov 12, 2011 | 05:14 AM
li_mustang's Avatar
li_mustang
i change the sensor on tranny all fix now,but for my stang have no idea i see somewhere a bad diode in alt must be the problem ,i check it ,it charge well
14.3 v any idea i dont wanna change my alt cause its good from what i see, ty sylvain from mirabel, quebec, canada
Old Nov 12, 2011 | 08:00 AM
JWA's Avatar
JWA
It's entirely possible something internal to your speedo and/or instrumment cluster has failed causing your hard shifting and loss of speedo indication.
I offer this only because I once changed a 1997 E250 gas motor cluster with one intended for a '98 E350 diesel motor and could not believe the driveabilty issues it created. No speedo, no MPG/KPH, would not shift at all------shocked me needless to say!
Since your cluster is original to the vehicle your symptoms sound vaguely familiar to my own experiences. Perhaps check the body wiring harness connectors into the cluster first, making sure they are firmly seated.
You don't mention of any other funcion of the cluster has been affected? Any of the temperature, pressure or voltage gauges seeming to not work or indicate within their normal ranges?
Hope we're being even a little helpful here Li Mustang!
Old Nov 13, 2011 | 07:41 AM
li_mustang's Avatar
li_mustang
ty jwa,only my speedo was down ,its ok now since i change the sensor on tranny,but this morning when i start it the engine service soon was onill pull th code later i will post for help for sure ty your a nice ford gang here,i really apreciate.
Old Nov 14, 2011 | 04:37 AM
JWA's Avatar
JWA
Specific codes are always a good idea----we'll look forward to seeing them, perhaps be even more helpful then!
FooFighter73
2015 - 2020 F150
Dec 19, 2017 04:24 PM
Etodd
Jan 11, 2013 01:17 AM
uponyou21
Nov 27, 2008 05:07 PM
Vinford
21
Apr 9, 2008 05:48 PM
pandadancing
1997 - 2003 F150
Apr 6, 2001 07:58 PM
