Speedo Not working
Old Oct 12, 2011 | 07:15 PM
IronRanger's Avatar
IronRanger
Speedo Not working
>1986 F250 4x4 6.9<
1: speedo gauge on cluster working
2: Cable is fine
3: Cable is push all way into gear.
4: gear looks good (gear on end of cable)
(when spun by hand it works. when put back into its place it doesnt)
Now the location of cable insertion is hard to see in, so cant see if something looks missing...
What Else am I missing?? is this something common for this trucks??
Thanks
IR
Old Oct 12, 2011 | 07:45 PM
ctubutis's Avatar
ctubutis
Welcome to FTE.
But, you're confusing....
Your Title says it's not working, but bullet point #1 says it *is* working!
What is the exact problem you're having?
Old Oct 12, 2011 | 07:50 PM
IronRanger's Avatar
IronRanger
Im just stating what Ive checked... Save some steps
The gauge is GOOD....
Sure its some gear in the transfer case but how can I know or how do i change it???
and thank you for the welcome
Old Oct 12, 2011 | 07:58 PM
ctubutis's Avatar
ctubutis
So, you're saying you can remove the cable from the transfer case and spin it manually and the speedometer works, correct?
In which case I'd be looking in that hole, a flashlight and a mirror on a stick would help you.
People here have talked about those drive gears sporadically but it's not real common.
You can probably get a replacement from your local Ford dealer but you should bring the old one in to compare.
How to remove it? No idea, I'd begin by taking the cover off the transfer case and looking inside.
This is assuming you haven't discovered something by looking in that hole, first; is it possible the cable isn't inserted all the way, or correctly?
Old Oct 12, 2011 | 08:24 PM
IronRanger's Avatar
IronRanger
Originally Posted by ctubutis
So, you're saying you can remove the cable from the transfer case and spin it manually and the speedometer works, correct? correct..
In which case I'd be looking in that hole, a flashlight and a mirror on a stick would help you. forgot about my auto mirror.. thanks for the reminder
This is assuming you haven't discovered something by looking in that hole, first; is it possible the cable isn't inserted all the way, or correctly? Id guess that if it works when remove it should work when put back into tranfer case.. Unless ur talking about it being in there correctly... dont know.. you slide it in.. bolt it down and that it.. (but some things can be picky)
Ill try to get my other trans case tomorrow and look over that as while..
Thanks...
(PS as a current and former mod on other sites, that is why I put the info up front)(yes I confuse myself at times)
thank you for your replies..
Old Oct 12, 2011 | 08:34 PM
ctubutis's Avatar
ctubutis
Thanks...
Cool.
Josh S
1983 - 2012 Ranger & B-Series
Nov 21, 2015 04:58 PM
daleyboy
23
Dec 11, 2013 04:33 PM
Swoop03
Oct 28, 2013 07:05 PM
FrontRangeF150
22
Jan 23, 2009 01:01 PM
