EGR DELTE
Old Oct 12, 2011 | 06:31 PM
BIGGMIKESFORD's Avatar
BIGGMIKESFORD
EGR DELTE
2005 f350 if i do a egr delete on my truck would it pass smog? im in Cali. Should i do it?
Old Oct 12, 2011 | 07:00 PM
RickF350's Avatar
RickF350
Doubt you'll pass. Try unplugging the EGR valve, bet you'll get a CEL.
Old Oct 12, 2011 | 09:40 PM
joe_r_dog's Avatar
joe_r_dog
If you do an egr delete, it will throw codes. this can be cured by getting an sct x3 tuner and getting a custom tune. since you are in cali, you wouldnt pass the test. the oem egr cooler was okay. only thing is, you will need to pull the valve and clean it with carb cleaner about every 20000mi. also, if you stay with the oem cooler, do a coolant flush and switch to some elc and get a coolant filter. best thing for a 6.0l. problem is, high egts are too much for gold coolant and could rupture your cooler. coolant will then go into the cooler and stretch your head bolts and your head gaskets will go. you can get an upgraded egr cooler made by bpd. many people in your area run them and there aren't any problems. you won't get a code then.
Old Oct 13, 2011 | 10:50 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Oct 13, 2011 | 12:09 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
You'll fail
Old Oct 13, 2011 | 01:31 PM
davidkstyler's Avatar
davidkstyler
BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0
You will still need to monitor engine coolant and oil temperatures.
Take a look in the Tech Folder for recommended temps.
https://www.ford-trucks.com/forums/9...-pressure.html
Old Oct 13, 2011 | 02:33 PM
U.P. Builder's Avatar
U.P. Builder
Yeah that ^ for Cali
Old Oct 13, 2011 | 08:59 PM
jammis's Avatar
jammis
If you are near the San Fernando Valley go by and talk to John at Diesel Performance shops in Van Nuys. He gave me some great insight into the whole EGR Valve/ EGR cooler/ Head Gaskets/ Oil Cooler Head Bolts etc. dynamic.
Old Oct 14, 2011 | 08:22 AM
tex25025's Avatar
tex25025
If you really work the truck, you shouldn't have to manually clean the EGR valve. 200K+ miles and I have yet to clean my EGR valve once and I'm flowing 40% more fuel and still on my original EGR Cooler and Oil Cooler.
Deleting the EGR System isn't the fail safe that a lot of people think that it is. I personally know of 3 people that did the EGR delete and still had to go rooting around there.
Old Nov 18, 2011 | 08:04 PM
BIGGMIKESFORD
Thanks for the info guys.
alxhockey
Jun 21, 2016 11:30 PM
Poorboy04
Apr 22, 2013 03:50 PM
ontarioford
Nov 25, 2012 09:21 AM
gmhorse
Jan 17, 2011 12:57 PM
jmaskew
Jul 9, 2008 06:34 PM
