Terminal Temps
Old Oct 12, 2011 | 08:46 AM
kbf1961's Avatar
kbf1961
Terminal Temps
I just returned from an intermountain trip towing a small trailer. I was just curious about the 230+ EOT,220+fWT temps I saw. What is the maximum oil temp on this engine before it melts down ?
Old Oct 12, 2011 | 09:22 AM
dchamberlain's Avatar
dchamberlain
Something like 300-350 before the plastic standpipe in the oil filter melts.
Those temps are OK. The thermostat isn't even fully open until 219 and your oil temperature is only 10 over the coolant which is OK. I've seen coolant as high as 225 and I wasn't even towing.
Old Oct 12, 2011 | 10:17 AM
npccpartsman's Avatar
npccpartsman
The engine oil filter stand pipe melts at 350* EOT. At that point your motor is toast and NOT rebuildable. Your temps are well within acceptable levels.
Old Oct 13, 2011 | 08:32 AM
kbf1961's Avatar
kbf1961
Thanks a lot guys.
Old Oct 13, 2011 | 09:01 AM
BLADE35's Avatar
BLADE35
just the main thing you want watch is the ECT vs EOT spread 15* max per ford
olfordsnstone
Jul 21, 2019 02:37 PM
Fandini
Aug 13, 2012 06:22 AM
2010F350
6.4L Power Stroke Diesel
Nov 29, 2011 08:44 AM
yz400f
Dec 1, 2009 02:08 PM
Blaster7Romeo
Jun 6, 2008 09:44 PM
