Heads back from Machine Shop...Which side is which? Pictures!
Old Oct 12, 2011 | 06:02 PM
garsm's Avatar
garsm
I just got my heads back from the machine shop today. I had them all marked up so I wouldnt forget which is which but of course they went through the bath and now I have no clue. The only clue is that little pipe coming off the one. I would assume that means it is the passenger side head and the end with that piece faces forward? Just making sure.
Other than that im ready to go. Been waiting 2 months now for the bore and head after I blew the engine. Not going wild but a few upgrades. bored .020 over, rosewood single shots, rebuild kit, and dp tunning. I will keep you posted on how it goes because im sure ill have more questions but heres some pictures so far and the piece im talking about.
The BAD!
Old Oct 12, 2011 | 06:07 PM
garsm's Avatar
garsm
Also, is this little gap between the top of the headgasket and the top of the block usual? And do I leave the thin metal rings around the cylinder holes on the headgasket in or do i take them out?
Old Oct 12, 2011 | 06:12 PM
Iallwork's Avatar
Iallwork
just looked at mine and yes that's where that pipe is. Looks like a hose goes off that to the heater core if I'm not mistaken.
Old Oct 12, 2011 | 06:29 PM
Poolguy601's Avatar
Poolguy601
Leave them in. They are the seal for compression.
Old Oct 12, 2011 | 06:50 PM
bulla's Avatar
bulla
That hose barb is pass side. Turn the motor over and you'll see why that ring is there. The piston actually sticks up out the block about a 1/16 of an inch. Good luck. Just curious, what did the head work run ya? Block?
Old Oct 12, 2011 | 06:51 PM
egreath's Avatar
egreath
yep yall are right i just rebuilt mine last month and i had the same question
Old Oct 12, 2011 | 07:00 PM
garsm's Avatar
garsm
Thanks for all the help guys. Better then second guessing myself. The block to clean, bore, and hone was $500. Both heads for valve jobs, resurfacing, injector tubes, and seals was $800. Putting some $$ into the truck but hopefully it will last for a long time.
Old Oct 12, 2011 | 09:56 PM
BobbyDiesel71's Avatar
BobbyDiesel71
please keep everybody up to date on your engine build up!!
what happened to your engine? miles?
what are you building it to do next?
Old Oct 13, 2011 | 01:06 AM
Bonanza35's Avatar
Bonanza35
Good post and pictures. Keep us up to date. Take pictures as you go and please post. We always like that.
Old Oct 13, 2011 | 03:24 AM
ChunderDownUnder's Avatar
ChunderDownUnder
I better not advise cause you guys have ya heads on the opposite side.
Old Oct 13, 2011 | 05:58 AM
bobbyrjw's Avatar
bobbyrjw
Did you do anything to your cooling jets to make sure that they don't fall out?
Old Oct 13, 2011 | 06:55 AM
bulla's Avatar
bulla
Is the op from over there?
Old Oct 13, 2011 | 07:22 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
No he's in PA so were good
Old Oct 13, 2011 | 07:48 AM
Snowseeker's Avatar
Snowseeker
Why aren't the headgaskets cleared for the pushrods right? The holes are in the wrong spots.
Old Oct 13, 2011 | 03:06 PM
garsm's Avatar
garsm
no, I only torqued them to specs....97 inch pounds. Is there something more I should have done?
