6.0 Trans Cooler Mod
Old Oct 13, 2011 | 08:37 PM
79OldBone's Avatar
79OldBone
thanks! thats helpful!
Old Oct 17, 2011 | 03:50 PM
79OldBone's Avatar
79OldBone
Hey Roentgeep, when you drip the hole for the egt's. How do you keep the metal shavings from going into the turbo when drilling? I take it you tap the manifold also and thread it in? That is the exhaust manifold in the picture right?
Old Oct 17, 2011 | 09:37 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
There are some opinions about the metal shavings:
Some people recommend to use first small drills and go up.
Others uses grease when drilling
other uses both methods.
I simply drill with the exact drill without any grease, the reason: the metal shavings are bigger and fall down during drilling, the grease goes inside the manifold and retain the shavings there. At the end of the drilling and tapping I just use a shop vac and a little magnet to get out the more possible the metal shavings. The drilling seems to be difficult, but was very easy.
Old Oct 17, 2011 | 09:45 PM
79OldBone's Avatar
79OldBone
well i have those dewalt bits that start a pilot hole then step up and cut through metal like butter and was gonna use one of those. do you tap it? or is it not think enough to need to and the probe just threads in?
Old Oct 18, 2011 | 09:00 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
You have to tap it. Just be sure what is the size of the probe threads because could be 1/4" or 1/8" NPT, all depends of the probe (gauge) brand. and dont go to far with the tap, just enougth, making some tests before finish it because its NPT
Old Oct 20, 2011 | 01:16 PM
79OldBone's Avatar
79OldBone
So ROENTGEEP before I drill this tonight, the best spot to drill is somewhere in the manifold? Thats what the picture is of right?
Old Oct 20, 2011 | 01:39 PM
superduty4x4's Avatar
superduty4x4
Yep, in the manifold just before the flange where the up pipe connects. Once you crawl under there and look you'll see there's a nice spot on the manifold to drill your hole.
Have you ever used a tap before? There's a right and a wrong way to do it. Also be sure you don't run the tap in too far, the threads are tapered and if you run the tap all the way in your fitting may not tighten down.
Old Oct 20, 2011 | 02:06 PM
79OldBone's Avatar
79OldBone
Alright thanks! Yeah I've used a tap before.. just new to diesels haha. And alright will do for the pipe threads.
Old Oct 21, 2011 | 12:56 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Yep what he ^ said
Old Feb 27, 2012 | 06:39 PM
LabCab's Avatar
LabCab
Does anyone have pictures of the 6.0 tranny cooler mod on a 7.3 Excursion, or SD?
I am considering getting the kit from John Wood and want to know how much work it would be. Ford just quoted me $1250.00 to do it and a tranny flush...... WOW.....
My 2002 Excursion has 172K on the clock with the original tranny. No issues, but I am picking up a 10K max load weight travel trailer in a month and want to make sure the tranny stays as cool as possible.
Thanks in advance.
Pat
EcoboostKev
Sep 7, 2014 07:47 AM
petrokiller
Jun 30, 2014 09:41 AM
jejenkins417
Jan 25, 2012 07:44 AM
john8403
Oct 7, 2010 10:11 AM
powerstrokin007
13
Aug 27, 2007 12:53 AM
