Sponsored by: Real Truck
Leaf Spring Modification/Ride Height
Old Oct 12, 2011 | 07:42 AM
Rose Clifford's Avatar
Rose Clifford
I bought my truck last December with 6" of lift and it's gotten me in some deep water here in Massachusetts. I need to take a couple inches out, but I don't want to spend a ton of money and get a whole new lift kit. I think it's a pro comp 6" suspension lift, but im not 100% sure of the brand.
My question is; Can I just remove some leafs from the spring pack? Off the top of my head I think there are 6 leafs in each spring, I'll get some pics up later when I get home. The front is all spring, the rear has blocks and beefier springs.
I'll need shorter U-Bolts....or can I just spin a dye on and lengthen the threads?
EDIT: FOUND SOME PICS!
Old Oct 13, 2011 | 10:34 AM
Rose Clifford
bump to top....any help peeps? I see I can probably remove the bottom leaf that isn't engaged...the flat/straight one, but how many more can I remove and still have 2000lbs in the bed.
Old Oct 13, 2011 | 11:29 AM
mwsF250's Avatar
mwsF250
Unfortunately, it will be a trial and error task to find which leaves to remove...
Do not remove any "full length" leaves.
I would advise against using a die to extend threads. Most U-bolts use rolled threads for greater strength. Dies tend to cut "sharp" roots in the threads, which are stress risers.
Have you tried finding someone to trade springs with?
Old Oct 13, 2011 | 11:43 AM
stumpbuster's Avatar
stumpbuster
yea dont mess with ubolts, bad move
also, EFF MASS......
all surrounding states are a breeze, but everytime im up in mass i get tickets, i would move
only 6"???
idiot cops
Old Oct 13, 2011 | 11:52 AM
Rose Clifford
only 6"???
idiot cops
I really am considering moving to NH, I work on the north shore but for now it's much cheaper to stay home and drop the truck down a couple inches. I'm currently fighting a license suspension for ride height and inspection tickets. It's such BS, it's going to cost me a LOT of money to get this sorted out.
What do you mean don't mess with the U-Bolts? I can get shorter ones, but as far as the leaf's go can I remove two to get 1.5" that way and hope it sags another inch or so? If I tell them I'm only lifted 3.5" I can get away with it, but 6" makes them cringe. Babies.
Old Oct 13, 2011 | 11:54 AM
Rose Clifford
Yeah like I said I'm going to use the process of elimination to remove the leaves. The straight thick one is coming out first. After that I'm just going up the pack removing what look like the 'helper' springs, nothing major is coming out. I'm probably going to compare to a stock leaf and move in that direction. Where can I buy new U-bolts only without paying a premium price?
Old Oct 13, 2011 | 12:37 PM
cablemanF250's Avatar
cablemanF250
Would be nice if all the states weren't idiots, i just looked up the lift laws, there are some crazy one's. But yes with the U-bolts you only can torq. them once, you will need new one's, I bought mine off of "streetsideauto" great price's & fast shipping, I also got my Pro Comp leveling leafs thru them, gave me a 2.5" leveling height, but it seems MASS. is a maximum of 2"s.
Old Oct 13, 2011 | 12:46 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Originally Posted by Rose Clifford
I see I can probably remove the bottom leaf that isn't engaged...the flat/straight one, but how many more can I remove and still have 2000lbs in the bed........straight thick one is coming out first.
You keep talking about still wanting to load the bed up with a couple thousand pounds... so pulling the overload might not be the best idea. It's contributing a whoping 3/4" right now (pad thickness), but it really does kick in once you load the bed down. As it starts to engage it basically stops the springs from de-arching. Your rear pack looks like two leaves were added, look at the pads on the end of each leaf, I'd bet there are two that are different, and I'd guess the 1st and 3rd up from the bottom, or the 3rd and 4th. The top leaf that goes from hanger to hanger, and the leaf with the clamps on it are probably part of the stock pack.
Like to took me forever to find this guy's pic of the overload getting hammered, still doesn't bend much with 5000# on it,:
https://www.ford-trucks.com/forums/1...l#post10625516
This is no sprung weight at all, adds less than an inch to the height of the pack:
Old Oct 13, 2011 | 01:30 PM
Rose Clifford
[quote=texastech_diesel;10916693]You keep talking about still wanting to load the bed up with a couple thousand pounds... so pulling the overload might not be the best idea. It's contributing a whoping 3/4" right now (pad thickness), but it really does kick in once you load the bed down. As it starts to engage it basically stops the springs from de-arching. Your rear pack looks like two leaves were added, look at the pads on the end of each leaf, I'd bet there are two that are different, and I'd guess the 1st and 3rd up from the bottom, or the 3rd and 4th. The top leaf that goes from hanger to hanger, and the leaf with the clamps on it are probably part of the stock pack.
[quote]
thanks for the words of wisdom. that picture is nuts! imagine the stress on those shackles. what do you make of the leaf thats above the rest, about 1" up from the pack on my rears??
Old Oct 13, 2011 | 01:59 PM
texastech_diesel
Token Redneck
Looks like the factory upper aux spring that came on almost all 350s and some 250s with certain packages. That's why I'm guessing you have an AAL in the back, because the overload, aux spring, the aux spacer, and the clamps all look stock. They could have maybe tried to rearch some of the stock springs, but my guess is a seriously arched AAL somewhere in the middle of the pack. The back end is light enough that you can lift it a couple inches with a single leaf that's stiff and arched enough. The rake from the factory 4" block and a 2" single AAL would net you almost enough to keep the back around where a 6" front lift would get you, probably dead level. But that's a WAG since I've never had a leaf spring front end on a SD.
bagman1995
Mar 23, 2018 07:07 PM
Anafiel
Dec 1, 2010 04:06 AM
amsk8er1983
Jul 27, 2010 11:37 PM
Huntfamily53
Sep 1, 2009 08:11 AM
Daviddc114
Mar 25, 2008 07:13 PM
