master cylinder pushrod length
Old Oct 11, 2011 | 09:40 PM
whitelighting89's Avatar
whitelighting89
a friend has a 67 F100 that we have recently did a cab swap on. The cab came off a 68 F250.... now here is the problem, we put a new master on it but even with the one that was on the truck the brake pedal was maybe 2-3 inches off the floor board. only thing I wonder is the pushrod longer on the f250 versus the f100 ? if so anyone know the length of the pushrod ? thanks
Old Oct 11, 2011 | 09:49 PM
whitelighting89
also I left the 68 pedal assembly in the cab and swapped the brake pedal from the 67. is there a difference in pedal assembly ?
Old Oct 13, 2011 | 08:11 PM
HIO Silver's Avatar
HIO Silver
I can't say for sure but I do know there are a ton of brake pedal arm/booster/MC combinations from 67-79. One of the main differences is distance between the fulcrum point (or pivot point) and where the pushrod is connected.
It sounds to me like your pedal arm either has shorter distance or the pushrod is too short. With proper welding, a pushrod can be fabricated, modified to fit, or ya simply swapping in the pedal arm from the old cab.
Get up there, measure it with a dowel (or similar), and then fabricate or find one of the proper length. IIRC, 65-73 Mustang vendors offer an adjustable version.
mckoloum
May 16, 2019 03:53 PM
Bowersdiesel
Aug 26, 2018 08:15 AM
revamp1953f100
Jun 13, 2018 03:17 PM
gduff93
Nov 9, 2013 04:23 AM
Junior
Aug 13, 2003 04:21 AM
