brake master cylinder and foot pedal relocation - Ford Truck Enthusiasts Forums
Old 06-12-2018, 03:51 PM
revamp1953f100's Avatar
revamp1953f100
revamp1953f100 is offline
revamp1953f100 is starting off with a positive reputation.
Cool brake master cylinder and foot pedal relocation
I've replace the front and rear suspensions on my 53 F100 pickup and now have disc's all around. Now I'm looking to mount a new master cyl w/booster on firewall and of course will be needing a new foot pedal hanger assembly. I suspect there are several suppliers out there that market this product (kit or individual parts) but my initial search thus far has uncovered something from Mid50. I'd be interested to hear from some of you experienced F100 resto dudes what your using and what you'd recommend... Thanks Texas-not so slim
Old 06-12-2018, 07:08 PM
EBEAR's Avatar
EBEAR
EBEAR is offline
EBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to behold
I used the pedal assy from the donor vette because I had it and didn't want to alter any part of the vette braking system .
Old 06-13-2018, 07:43 AM
avf100's Avatar
avf100
avf100 is offline
avf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to behold
I used the Mid-fifty kit. I didn't like how high the pedal was. I straightened the pedal arm some, and adjusted the push rod to move the pedal closer to the floor.
Old 06-13-2018, 07:57 AM
avf100's Avatar
avf100
avf100 is offline
Old 06-13-2018, 03:27 PM
revamp1953f100
Hey john or avf100... Thanks for the response with the pic's . I've been looking at the various brake kit suppliers and both CPP and Mid50 are on my radar. Your two pics are a little confusing, i.e. the master cylinder appears to be the CPP and I think you implied the brake system kit you used was the Mid50.. Is the in-cab bracket and hanger/footpedal mid50 or CPP..Just curious ... Yours looks to be a sweet clean install either way.. I'm also shopping for tilt steering columns.. Who's did you use..? the clearance around steering linkages between column and the rack& pinion is a concern because of the exhaust manifold/header is a big obstacle..who's headers did you find worked for you ? It all looks sweet. Roger
Old 06-13-2018, 04:15 PM
Rusted56's Avatar
Rusted56
Rusted56 is offline
Rusted56 is a splendid one to beholdRusted56 is a splendid one to beholdRusted56 is a splendid one to beholdRusted56 is a splendid one to beholdRusted56 is a splendid one to beholdRusted56 is a splendid one to beholdRusted56 is a splendid one to beholdRusted56 is a splendid one to behold
Thru Firewall Mount : Kugel Komponents, Quality Komponents Since 1969
I used these guys...not super cheap, but excellent quality.
As for columns, do your research and pay the money for good quality
https://www.lvvta.org.nz/documents/i...ng_Columns.pdf
Old 06-13-2018, 04:17 PM
avf100's Avatar
avf100
avf100 is offline
1- CPP makes the kit that Mid-fifty sells
2- The column is an Ididt floor shift
3- The headers are Hedman headers....But I have a chevelle frt frame clip with a SBC ..no rack & pinion it has a steering box
AbandonedBronco
1978 - 1996 Big Bronco
38
03-17-2018 05:17 PM
KawiRider78
20
06-03-2011 11:06 AM
Spool&Go
27
07-22-2010 11:12 PM
bsirvine
07-25-2008 03:42 PM
jenkinsj
09-04-2005 05:12 AM
Quick Reply: brake master cylinder and foot pedal relocation
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
