axle splines
Old Oct 11, 2011 | 08:30 PM
vettman's Avatar
vettman
axle splines
Can someone please tell me how to determine the number of splines on the rear axles of my Dana 70 differential. I have an OEM Dana 70, with 4.10 gears in my '76 F-350. Is this info stamped on the housing? on the tag?
Also, for this vintage Dana 70, will it be a "U", "B", or "HP"?
Thanks
Old Oct 11, 2011 | 09:14 PM
HIO Silver's Avatar
HIO Silver
I googled "Dana 70 bom" and came up with lots of hits. This seems to be a good one: Dana 70 Solid Front & Rear Axle info
Dana 70 Rear
Found under light pickup trucks info:
Splines: In my Spicer books all 67+ axle have 35 splines! Unless they are from a Ford F-350 truck with dual rear wheels. "1967-1975 Ford F-350's dual rear wheels & other" have axle shafts 34414-1 or 35368-1 and thus 23 splined 1.5" axle shaft. One note, they sure have a lot of No-Spins in them.
Dana 70 Facts: Axle Type: Full floating, carrier type housing and hypoid gears. Yoke: D70 has a 1350 flange (3-1-4041x) or a 1350 U-joint (3.4.5731x) or a 1410 U-joint (3.4.5711x) yoke for the drive shaft connection. Weight with out brakes 300 lbs. Torque: Max 7,000 Lbs ; Continuous 1,750 Lbs. Nominal GAW Rating 7,500 Lbs Wheel bolt patterns 8 on 6.5"
Dana 70 HD Facts: Axle housing tubes are 4 inch thick.WMS-WMS is between 70 - 50.75" Nominal GAW Rating 10,000 Lbs. Wheel bolt patterns Hub only 5 on 8.0" or Hub and Disk 6 on 8.75"
Wikipedia: Dana 70 - Wikipedia, the free encyclopedia
TheRangerStation: Dana/Spicer Bill Of Material Numbers
Good luck.
Old Oct 11, 2011 | 10:03 PM
montana_highboy's Avatar
montana_highboy
Either 23, 32 or 35 spline, yours 'should' be a 35 spline unit as per the info above.
Old Oct 12, 2011 | 06:01 AM
Poison Oil Racing's Avatar
Poison Oil Racing
if it is a full floater then you should be able to remove the axle shaft easily and count the splines, but I would go with 35.
Old Oct 12, 2011 | 07:23 AM
vettman's Avatar
vettman
Thanks for all the replies/good info. Now how do I tell if I have a Dana 70 B or U--I know it's not an HD. Is there a "plain" Dana 70 without a letter code?
Thanks
Old Oct 12, 2011 | 09:33 AM
vettman's Avatar
vettman
Here's a link to a Dana catalog for all their differentials used in '67 to '78 vehicles. Lots of good info. I'm not sure the URLs are hyperlinked correctly.
[URL="http://www2.dana.com/pdf/X510-SD.pdf"]
Here's another good link for info on the Dana 70:
[URL="http://pirate4x4.com/forum/showthread.php?t=522333"]
armikk
Competition
May 19, 2010 08:53 PM
fourfoot23
Jun 6, 2004 09:26 PM
Ryan50hrl
Aug 25, 2003 01:30 AM
Franklin2
Nov 30, 2001 08:35 PM
