Hey guys platnium pete is having is issues with a oil leak in the front of the valley
we believe its an issue on the low pressure side of the pump
Does anyone have a picture of the pump that labels what ports/plus are low pressure and which are high
Also what would masked the oil leak be much worse on cold start after sitting the day before... Leak iss not nearly as bad when it only sits over night
When I had my HPOP leak it would fill the valley as I drove then drip down the back of the engine all night. I had a 4"-6" puddle under my truck every morning.
I cleaned the HPOP and every hose/plug fitting then started it and checked each one and found fresh oil coming from the non-serviceable/removable plug. Cleaned it again, checked again, and it was the culprit for sure so I ordered the kit and replaced most of the rings on the HPOP and fuel bowl.
