96 F150 2WD Alignment issue
Old Oct 10, 2011 | 01:38 PM
Cimarron's Avatar
Cimarron
Pulling to the left. First mechanic replaces upper and lower ball joints passenger side. He doesn't have the machine to align.
Second mech. Aligns by the numbers. Still pulls left. Says needs cambers, can't do the job they say and this is AAA shop.
Ford Dealer, 5 hours later, new cambers rotated new tires to the front, gives it back. Not even 1/4 mile down the road it pulls left (how in the %$#@ can they return your truck like that?
Back in the shop today. Dealer says the numbers are right one and they have to charge a diagnosis fee to find the problem.....
Is this a matter of replace and see? Anyone with this experience. Truck had been running true but started pulling before replacement of ball joints. Thanks for any input (190,000 miles Inline 6 would like to keep it)
Old Oct 10, 2011 | 05:20 PM
Ed Bamba's Avatar
Ed Bamba
Just a thought, could it be that one of the front brakes may be dragging?
Old Oct 10, 2011 | 06:00 PM
bashby's Avatar
bashby
I did fea's for years. 99% of the time a pull is caused by the tires. Cross the fronts left to right and see what happens. Most likely it will pull right and it may not pull at all.
Old Oct 10, 2011 | 06:09 PM
dustybumpers's Avatar
dustybumpers
Front rubber brake lines need replaced. they're hanging up. Jack the truck up, roll the tire, then apply the brake. release the brake, and roll the tire again, I bet it don't want to roll.
Old Oct 10, 2011 | 07:29 PM
Cimarron's Avatar
Cimarron
7:30 to 5:00 pm
Much obliged to all.
The dealer, first time that I've used them, Ed Bamba...they told me that might be it...wasn't.
bashby....they did that with all the combinations possible, note new tires.
dustybumpers...they told me it wasn't in the brakes, they mention calipers hanging up.
Haven't picked the truck up yet, they had it till closing.
They told me they ended up over adjusting to make up the difference, or went outside the parameters a little to align it. Also, I've been using a Suicide handle or some call it a Brody and it was at the 8 o'clock position, its a little heavy, they said that was part of the steering to the left...hmmmm.
It does have 190,000 miles on it but I'm sure there are plenty of much older trucks out there that don't have this issue. Not sure if the "over adjustment" is a professional job coming from a Ford Truck dealer.
Old Oct 10, 2011 | 07:40 PM
dustybumpers
I don't know either, my 94 has 244,000, steers straight. My 89 has 480,000, and it steers straight. both are aligned to ford specs.
A sticking caliper will cause it to pull, and a worn brake line will cause the brakes to drag. There are many variables in a front end
Old Oct 10, 2011 | 09:37 PM
Cimarron's Avatar
Cimarron
brakes
I hear ya on the brakes, there actually new three months ago. How did ya get 480,000 on the 89. Rebuilt motor? Inline 6?
Old Oct 11, 2011 | 06:16 AM
dustybumpers
Inline 6, motor is origional, replaced 1 pushrod and rocker arm, and a water pump. oil is changed every 3,000 miles, antifreeze every 3 years. I have done this ever since the truck was new. I'm going to pull it this winter, and freshen it up, the oil pressure has dropped some in the last 6 months.
Old Oct 11, 2011 | 06:29 AM
Cimarron's Avatar
Cimarron
dustybumpers going strong
much obliged to ya, that's great incentive to keep up with my present truck of which I'm 30 minutes early, sitting here at the dealership service department waiting for them to open. I've got extra keys with me and thought about driving off and just call in and give them the card over the phone but I'm sure that wouldn't go over very well.
muddman77
Jul 26, 2009 12:04 AM
Stone Mathews
May 19, 2008 03:14 PM
Bronco308
May 11, 2006 05:53 PM
RickyD
Dec 27, 2004 12:56 PM
ChargerFan
Oct 12, 2004 12:02 PM
