Voltmeter install Question
Old Oct 10, 2011 | 01:00 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Picked up this to install next to my footpedal adjust switch on the dash
Where can I hook this up to read battery voltage? I'm going to use a relay to turn on/off.
Old Oct 10, 2011 | 01:09 PM
dchamberlain's Avatar
dchamberlain
On 03-04 trucks there is a fused and switched wire coming out of the wiring bundle just before it gets to the OBD-II connection. It is white with a light blue stripe and is powered by 10A fuse #29. I assume it exists on later model trucks, but is probably a different fuse #.
I doubt that thing draws enough current to need a relay.
Old Oct 10, 2011 | 01:29 PM
69cj's Avatar
69cj
If you want it off/on use an upfitter sw. if you have them.
Old Oct 10, 2011 | 02:20 PM
_Me2_'s Avatar
_Me2_
It's just a voltmeter. Tie the power to a 12V wire that is switched off with the ignition. No need for relays or upfitter switches. Use whatever 12V source you are going to use for your other gauges. Your ScanGauge II also reads volts, in case you hadn't seen that.
Old Oct 10, 2011 | 06:45 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I am looking for the most direct 12v source under the dash. The more wires you have between battery and gauge, the less accurate this gauge will be. I was hoping to pretty much read a direct battery voltage...but was trying to avoid running a wire directly from the battery pole.
oh well, easy enough to run a 4' wire to the drivers side battery.
I've been watching the voltage on my Scangauge II, but want to free up that slot for another parameter. Currently watching ECT, EOT, FICM, Volts. Also have a 4 pod on the pillar for LPOP, Fuel, Boost, EGT.
My OCD nature would drive me crazy if I use an upfitter to power this gauge. I would want it on all the time...and having 1 of the 4 up all the time...not good for my peace of mind
Cooter55
May 2, 2018 06:49 PM
BCM
Jul 28, 2017 06:47 AM
Lucca
Apr 28, 2012 11:21 AM
fordf150farmer
Electrical Systems/Wiring
Feb 25, 2011 09:51 AM
TheKirbyMan
'80-'86 FAQs (Frequently Asked Questions)
Dec 5, 2010 11:26 PM
