Lower ball joint nut seized. Need help.
Old Oct 9, 2011 | 07:43 PM
Growl60's Avatar
Growl60
I was able to get the top nut by grinding it off but the bottom is totally seized. I used pb blaster to no avail and a breaker bar. Impact wont fit in there or the grinder. Any suggestions?
Old Oct 9, 2011 | 07:55 PM
bashby's Avatar
bashby
oxy acetylene torch, sawzall....
Old Oct 9, 2011 | 08:00 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
X2 on the acetylene.then a BIG hammer!
i wouldn't touch a ball joint without both of those tools (bare minimum.)
Old Oct 9, 2011 | 09:08 PM
jroehl's Avatar
jroehl
For starters, I'd get some rust-eating penetrant and a wire brush on that bad boy. Clean it all up so your sockets have half a chance of grabbing.
Jason
Old Oct 9, 2011 | 09:13 PM
Edgethis's Avatar
Edgethis
I just tackled this on my Bronco this weekend. A BFH is required as is the already mentioned torch. But Jroehl nailed it. You need to try and clean those threads up of you wanna get that nut off.
Old Oct 9, 2011 | 10:49 PM
StumpPullerF1's Avatar
StumpPullerF1
I would agree with everyone else about the cleaning and brushing, but i would use a 6 point socket, breaker bar, and a 4' piece of 1.5" tubing to get it loose. Not sure what the hammers for until the nuts off. Anyways good luck.
strokin'_tatsch
Mar 16, 2011 01:39 AM
ExtrmZ
27
Aug 23, 2010 12:12 PM
sail2244
Oct 3, 2007 07:53 AM
supaJoeSHS04
Aug 12, 2005 03:57 PM
andym
1978 - 1996 Big Bronco
Oct 16, 2003 07:26 PM
