Need turbo install help
Old Oct 9, 2011 | 07:15 PM
Otahyoni's Avatar
Otahyoni
Getting pretty well done.... can't get the down pipe in place though. Whats the trick to getting it in?
This is a first gen Banks kit with a 3" DP...
Old Oct 9, 2011 | 07:23 PM
joe f350's Avatar
joe f350
the oil plug is the the tranys adapter plat i had the same problem when i was installing mine
Old Oct 9, 2011 | 08:30 PM
Coalroller's Avatar
Coalroller
the one on the right is coolant and the one on the left (if a square head) is an oil pressure so it can be used, also like joe said there is another square head plug back on the drivers side right at where the exhaust manifold meets the crossover pipe that can be used
also to use either i would make your own feed line.
Old Oct 9, 2011 | 09:15 PM
Otahyoni's Avatar
Otahyoni
Not sure what you mean by make your own feed line. I only got a partial kit so i had a local place make me a couple of stainless steel braided lines...
Snapon showed me a pic over on OBN, so i found the plug i need.
Also got instructions from Russ to clean out the passage before i hook the oil line to the turbo.
Old Oct 10, 2011 | 06:14 AM
Coalroller's Avatar
Coalroller
yeah if you had a shop make u some braided ss lines then your good, thats what i meant about the make your own feed lines
Old Oct 30, 2011 | 03:36 PM
Otahyoni's Avatar
Otahyoni
Updated the OP...need more help...
Old Oct 30, 2011 | 04:08 PM
91dirtydiesel's Avatar
91dirtydiesel
Help with.....?
Old Oct 30, 2011 | 05:04 PM
snaponprofile's Avatar
snaponprofile
I dunno about doing it on the first gen. but I had to put mine in from the top.
Old Oct 30, 2011 | 06:21 PM
Otahyoni's Avatar
Otahyoni
I got it. Used a 2x4 to smash the firewall what i could and stuffed it in from the bottom.
IT RUNS!
I'll be damned if it isn't the quietest though.... can barely hear the thing, even when revving....
Old Oct 30, 2011 | 06:43 PM
Aune163rd's Avatar
Aune163rd
Sounds like a leaking pipe....
Old Oct 30, 2011 | 08:22 PM
Otahyoni's Avatar
Otahyoni
Nothing leaking on the up pipe...check closely.... we'll see how it sounds once i get some pipe behind it...
Old Oct 31, 2011 | 12:28 AM
Aune163rd's Avatar
Aune163rd
it might be the crossover, you might not have it bolted down tight enough....
Old Oct 31, 2011 | 03:54 AM
tjc transport's Avatar
tjc transport
i ain't rite
the turbo is very quiet.
until you get up around 2000 rpm, then you will hear it a little
Old Oct 31, 2011 | 03:10 PM
Aune163rd's Avatar
Aune163rd
I beg to differ tjc, jayme's can be heard from about 1000 RPM up....
Old Oct 31, 2011 | 06:33 PM
Otahyoni's Avatar
Otahyoni
Some i've heard are very noticeable even at idle.
