Pedistal
Old Oct 9, 2011 | 04:21 PM
Bonanza35's Avatar
Bonanza35
Pedistal
I was wondering if anybody has the measurments on either the early or late model Pedistals, or both. I got a complete set from a freind that is suppost to be the late model. I know the turbo is but the uppipes measure the same as my early style on the truck. I haven't taken them off yet because I don't want to get in the middle with the wrong stuff. Top to bottom should be alright. Thanks, Chet
Old Oct 9, 2011 | 05:23 PM
leekingen's Avatar
leekingen
the late pedistal is about 1/2 inch taller. you will nead longer pedistal bolts as well as new up pipes for a late model truck.
Old Oct 9, 2011 | 05:44 PM
Bonanza35's Avatar
Bonanza35
I know its taller but do you have the height? I ask this because I want to measure the one I have before I take mine apart. I hate to take mine apart then have to wait to order a different pedistal. I tryed to see if I could measure it on the truck but its all but impossible. Thanks Chet
Old Oct 9, 2011 | 06:14 PM
leekingen's Avatar
leekingen
you will nead a late pedistal if you are coverting to a late turbo,what all do you have now? i have convertid my early to late turbo.
Old Oct 9, 2011 | 11:37 PM
Bonanza35's Avatar
Bonanza35
I have the late turbo, spider, pedistal and uppipes but, the uppipes measure the same as the ones on my early 99. At least with it still in the truck. And the pedistal had 99 writen on it. I know the late 99 had the upgraded turbo. Because of the uppipes I'm not sure on the pedistal now. Chet
Old Oct 10, 2011 | 05:10 AM
leekingen's Avatar
leekingen
The uppipes are about a 1/2 inch longer also.don't think u can measuer them on the truck.did u get the plenums?
Old Oct 10, 2011 | 06:07 AM
leekingen's Avatar
leekingen
I do have my early pedistal and I will take some measurments when I get home to night.
Old Oct 10, 2011 | 11:38 AM
Bonanza35's Avatar
Bonanza35
[quote=leekingen;10904194]I do have my early pedistal and I will take some measurments when I get home to night.[/quot
Thanks Leekingen. If you measure the early pedistal I'll know if I have the write one to update. If mine is taller it has to be the right one. Great
Chet
Old Oct 10, 2011 | 05:06 PM
leekingen's Avatar
leekingen
chet my early pedistal is 3 3/4 inch high i hope this helps, if you have aney problems when you do this let me know.i
Old Oct 10, 2011 | 05:44 PM
Bonanza35's Avatar
Bonanza35
Thank you and God bless. I just got this E-mail and went right out and measured mine. Its 5 1/16 so I got the right one. Thats from the bottom to the highest point. Now if the uppipes work I'm in business. You help is appreciated thanks again, Chet
Old Oct 10, 2011 | 05:53 PM
Bonanza35's Avatar
Bonanza35
Leekingen, seems we have the same truck. Mine was built 9-98. How do you like the upgrade with stock injectors. Also did the 140v idm make a difference. I had a bad #8 fuel knock just put Clays Frx in it helped a lot. I want new injectors but mit just change that one out first. Do you tow? Just wondering on boost and power. i have the DP tuner and T500 HPOP. The HPOP increased my mpg by two at 78mph freeway and way better power up top. Chet
leekingen's Avatar
leekingen
Thas good to hear. I hope things go well fore you.take your time with this and you should be ok
Old Oct 10, 2011 | 06:32 PM
leekingen's Avatar
leekingen
chet the truck runs great, good boost geat power,no i dont tow but i will next summer . i have ben thinking about the t 500 but im on the fence on that.i just wont to see how this works for me. i did not see if you had late plenums?
Old Oct 11, 2011 | 12:40 AM
Bonanza35's Avatar
Bonanza35
The plenum is 1 1/4 inch taller then the one you measured so it must be the late one.
Chet
Old Oct 11, 2011 | 08:27 AM
leekingen's Avatar
leekingen
Plenums are a sheetmetal part that bolts to the intake of the heads thay have 3 in diameter opining.early 99 have a 2 1/2 inlet.a key part of this upgrade
