Fresh build thread :D
Old Oct 23, 2011 | 07:17 AM
  #31
muscletruck7379's Avatar
muscletruck7379
its a system that works. cost no power or mileage (might even help).
think about the planet man!
Old Nov 3, 2011 | 02:28 AM
  #32
Grendelx's Avatar
Grendelx
Ok... install started today... got the engine hooked up to the tranny (which was left in the truck) but can't figure out the trick to the mounts.... 79 f150... 4wd... any suggestions?
They should fit just fine once they're in, but dunno how to get them there... studs on the bottom of the pads are too wide to just drop into the holes...
Old Nov 3, 2011 | 08:37 AM
  #33
SideWinder4.9l's Avatar
SideWinder4.9l
How did you unhook them then? Logic dictates if it came out of a specific place, it must go in...
Maybe just some rusty buildup that needs to be removed?
Maybe the whole engine/ tranny combo is slightly twisted and fouled in such away that won't allow the movement your looking for?
Old Nov 3, 2011 | 11:30 AM
  #34
Grendelx's Avatar
Grendelx
new mounts... with the old ones the rubber was completely seperated... so I just lifted it off the pads... leaving me with no idea as to how it's _supposed_ to come apart.
Old Nov 3, 2011 | 12:55 PM
  #35
muscletruck7379
#1: unbolt and remove the old mounts!
actually, you might want to check and see if they are stamped R or L for which side they go on.
after struggling with parts stores for mounts for my 88, I finally just drilled through them and used two bolts to hold them together.
Old Nov 4, 2011 | 03:51 PM
  #36
Grendelx's Avatar
Grendelx
turns out the mounts they gave me are wrong... they spread out just a little bit too much to drop into the holes in the towers, and theres no way to work em into position....
Old Nov 6, 2011 | 04:18 PM
  #37
Grendelx's Avatar
Grendelx
Got it in over the last couple of days... some "gentle persuasion" helped with the mounts... it started up first try, and everything is doing exactly what it should... life is good
Now to reassemble the clutch linkage, and take it for a spin
trozei
92
Aug 19, 2022 05:08 PM
cleatus12r
23
Jun 23, 2019 03:14 PM
acl9865
Oct 7, 2017 07:07 PM
AbandonedBronco
95
Jan 27, 2015 08:18 PM
nunrush
Aug 5, 2010 03:58 PM
