Straight Piped, any harm?
Old Oct 9, 2011 | 06:41 PM
JOHN2001's Avatar
JOHN2001
Originally Posted by 02 Stroker
he owns a small trucking company where he does a lot of the work too. his stepson is a mechanic, he drives a F350 7.3L too. But i agree he was wrong this time
Point blank..... Your neighbor is an idiot! Your engine does not need back pressure. The less the better
Old Oct 9, 2011 | 07:24 PM
BioHazrdMan's Avatar
BioHazrdMan
What everyone else said... Here is a linky for a stock muffler delete pipe if you need it!
99-03 Ford 7.3L Powerstroke Diesel Stock Muffler Delete Pipe
Old Oct 9, 2011 | 07:50 PM
hotroddsl's Avatar
hotroddsl
The only engine design that has the need for a muffler/ back pressure system is a gasoline two cycle as the muffler is acting as an expansion chamber pulling fresh mixture into the cylinder, diesel and gasoline engines only have mufflers to keep people happy not the engine! Back pressure is the enemy! Period!
Jim &fat Monty
Old Oct 9, 2011 | 08:13 PM
Franko72's Avatar
Franko72
Molon Labe
Jim &fat Monty
I COMPLETELY agree!
Old Oct 9, 2011 | 08:30 PM
02 Stroker's Avatar
02 Stroker
I thought I could just cut the muffler off and flip the s pipe on the engine side and run a straight pipe to reach the pipe that was after the muffler
Old Oct 9, 2011 | 09:44 PM
Kwikkordead's Avatar
Kwikkordead
well for noise i think im alright there, my neighbor has a straight piped cummins.
They only sound good at idle.
Throttle one of them up and I would rather have a muffler on.
Old Oct 9, 2011 | 09:48 PM
gatormccluskey's Avatar
gatormccluskey
I did a muffler and cat delete on my 99. I love it. Its not to loud for me. At idle I cant tell its gone. In a good pull, it sounds great. Just my .02
Old Oct 9, 2011 | 10:07 PM
binuya's Avatar
binuya
That will work too. When I installed a Walker BTM on my original system, that is what I did with the 'S' pipe. Just spun it till it all lined up.
Old Oct 9, 2011 | 10:22 PM
Krazymaan's Avatar
Krazymaan
The only harm will be on the guy in your mirror that has to keep rolling up his window.
Old Oct 9, 2011 | 11:28 PM
Nsaan's Avatar
Nsaan
I for one have to disagree, my Cummins is straight piped 4 inch turbo back with a 6 inch tip and it sounds GOOOOOD it makes people notice at idle and when I am pulling hills or going through a tunnel or just happen to have some one next to me I always have the passenger window cracked so I can hear it talk, she sounds really good pulling 30+ pounds of boost.
I guess I am just nuts for a turned up diesel though, cause I think Cummins, Cat, Detroit, Power Stroke and D-max all sound good when then are rippin!
Old Oct 10, 2011 | 08:36 AM
JOHN2001's Avatar
JOHN2001
While I won't argue with you when there making boost they sound awesome. Not under boost just cruising they all sound like crap in my opinion
Old Oct 29, 2011 | 09:18 PM
02 Stroker's Avatar
02 Stroker
i thought i would just do an update on this thread, I did what i said and flipped the s pipe and welded in a straight pipe in place of the muffler, exits in the same spot until I find a 5" tip and run it like a duramax
Old Oct 30, 2011 | 01:44 AM
  #28
Nsaan's Avatar
Nsaan
I got a Diamond Eye 3.5 to 4 inch down pipe for my 7.3 so I wouldn't have to beat the firewall up to make it fit. I have all the other stuff to run my single stack up the back of the cab inside the frame rail so my kids (and me) don't burn the crap out of themselves on it. I even bought a 4 inch rain cap. I am thinking of painting it all flat black, I bought high temp BBQ paint so it would not look all dirty when the smoke comes out
I am not sure just when I will get around to the install, it should be rather easy as got the nice band clamps for it, I even got a nice stainless flex to put in it so I don't have the same problems with breaking that I have with my Cummins, 4x4, not that I think my f450 will flex or ever be taken anywhere the Dodge has been....
I talked to a muffler shop and got a quote from them to build it... they wanted more for the down pipe then I paid for everything!
I need to hurry up on it since I am waiting on my gauge install till I have it in, so I can weld a bung in the down pipe elbow for the pyro.
.....Yes I know it is not the best place for a pyro, but it is a work truck that never tows heavy... all that means in that location is I don't go over 1100 degrees.
Old Oct 30, 2011 | 01:52 AM
  #29
timmyboy76's Avatar
timmyboy76
Think your neighbor gave you that line of B.S., cause he doesnt like the idea, and try'n to save himself, some more sleep?
sudsmcduff
Sep 17, 2013 10:09 PM
H71993
13
May 16, 2009 08:30 PM
palmer1155
Dec 6, 2008 06:17 PM
bigsteve1969
21
Apr 13, 2008 11:38 PM
UP_There
Oct 24, 2007 07:52 PM
