Straight Piped, any harm?
Old Oct 9, 2011 | 12:45 PM
02 Stroker's Avatar
02 Stroker
We got a 2002 F250 7.3l AT, so far its bone stock performance wise. I want to do a muffler delete with just the stock 3.5" pipe and then put like a 5" tip on the end. Not ready to run a full 4" turbo back so Im hoping this will make it sound a little better.
I talked to a neighbor who said it will harm the engine because the valves need backpressure to function properly, I think thats wrong cause dont the turbo provide the backpressure needed? Wouldnt a free flowing exhaust HELP the engine perform better?
Ive searched and found answers but dad wanted me to post my own topic to be absolutely sure it wont damage anything.
Also we pull a 9K pound camper a few times a year so would a straight pipe help or hurt pulling power?
thanks,
Randy
Old Oct 9, 2011 | 12:50 PM
binuya's Avatar
binuya
No harm whatsoever. It will reduce your egt's.
Old Oct 9, 2011 | 12:52 PM
JamesHajek's Avatar
JamesHajek
No. Your turbo creates all the backpressure your motor needs... Straight pipe will not hurt a thing...
ToMang07's Avatar
ToMang07
Won't hurt a thing, but is technically illegal, and many states will fail you for inspection with no muffler.
Old Oct 9, 2011 | 01:37 PM
Robert6401's Avatar
Robert6401
It's actually better for your truck since you use it to tow. Doubtful your EGTs ever get that high with a stock tune and only towing 9,000lbs, but it will reduce the temps, and lower EGTs are always better.
Old Oct 9, 2011 | 02:21 PM
Kwikkordead's Avatar
Kwikkordead
Go for it, the turbo produces more back pressure than your muffler will ever generate.
Old Oct 9, 2011 | 02:23 PM
mtdigger's Avatar
mtdigger
It may hurt your neighbours sleep patterns...but truck wise....no harm, hacked mine off just before the muffler about a year ago....zero problems
Old Oct 9, 2011 | 02:39 PM
Franko72's Avatar
Franko72
Molon Labe
I agree with the others, I've been running straight pipes for a few years, And I pull quite a bit.
Although I dont think my neighbors care for my high idle...
Old Oct 9, 2011 | 02:53 PM
levimorris85's Avatar
levimorris85
I did the exact same thing 7 years ago and 100k miles and I have had ZERO problems with the motor. I cut the muffler out and welded in a piece of 3.5" and drove it like i stole it and wouldn't change it back. As far as inspections go, i havnt had a problem.
Old Oct 9, 2011 | 03:35 PM
GR$$N$'s Avatar
GR$$N$
when i first did that i just put a turndown on where i cut out the muffler.worked great and egts were much lower.i live in california and theres no problem whatsoever with smog.all they care about is a cat and my 7.3l is a non-catalyst motor so you should be good
Old Oct 9, 2011 | 03:52 PM
SpringerPop's Avatar
SpringerPop
What credentials does your neighbor have for giving you diesel advice?
See?
Pop
Old Oct 9, 2011 | 04:45 PM
Firefighter 1406's Avatar
Firefighter 1406
Ran my truck that way for three years before my turbo back just fine. Like mentioned it is loud but it sounds so good
Old Oct 9, 2011 | 04:52 PM
02 Stroker's Avatar
02 Stroker
well for noise i think im alright there, my neighbor has a straight piped cummins.
the neighbor that told me that has been working on cars for years, owns a trucking company and usually knows what hes talking about, but i didnt believe him this time.
Thanks all, proved what i already believed
Old Oct 9, 2011 | 05:47 PM
SpringerPop
"Usually" is the operant here.
Has he been working on diesel cars?
And even if his "trucking company" uses diesels, as a general rule, owners don't know nearly as much about their rigs as their employees do.
Neighbor may be really smart. Dunno'. He certainly gave you incorrect information this time.
Pop
Old Oct 9, 2011 | 06:06 PM
02 Stroker's Avatar
02 Stroker
he owns a small trucking company where he does a lot of the work too. his stepson is a mechanic, he drives a F350 7.3L too. But i agree he was wrong this time
