Another Gauge Question???
Old Oct 8, 2011 | 04:10 PM
Skyblaster2000's Avatar
Skyblaster2000
I have a 1993 7.3 turbo diesel 4x4.. I have a trans temp gauge and I have no idea where to put the ssensor on my manual tranny??? Any anwsers would help thanks
Old Oct 8, 2011 | 11:46 PM
tecgod13's Avatar
tecgod13
There is no place to put the sensor on a manual tranny. For the most part, its not needed as the fluid won't heat up like it would on an automatic.
That being said, if you do a lot of towing, or in a very warm climate, you might be interested in the temp. You may be able to fine a sensor that will replace the drain plug.
Old Oct 9, 2011 | 12:49 PM
IDIDieselJohn's Avatar
IDIDieselJohn
You can always drill/tap the PTO cover on the passenger side of the tranny.
Old Oct 9, 2011 | 06:46 PM
tecgod13's Avatar
tecgod13
Wow, yah now I feel dumb.. Thats a real good solution for our tranny's! Plus you could choose whichever side you wanted.
The cover is pretty thin, so tapping it might not hold the best. But they are easy to pop off, so would be a piece of cake to weld a tapped bung on.
Old Oct 9, 2011 | 08:57 PM
IDIDieselJohn
Or take it off, drill it, and weld a nut from the inside.
4drf350
Jul 11, 2009 02:04 PM
NeuralMonk
May 7, 2007 03:09 PM
hosemandc
Feb 22, 2007 04:52 PM
DL
Mar 29, 2004 12:42 AM
karenj
Nov 21, 2003 06:39 PM
