Harpoon and Zoodad complete...
But when the nozzle does click off, you are still several gallons short of a full tank!
You can be happy with that, or you can keep clicking the nozzle for the next 10 minutes to get it full.
Or you can do the Harpoon mod so that the nozzle doesn't click off until the tank is actually full
On my shortbed, before the Harpoon mod it would only take 26-28 gallons before the nozzle started clicking off,
after the Harpoon mod it takes 30-30.5 gallons when it clicks off the first time!
PS: the fuel gauge is just like the temperature gauges on the dash...over glorified idiot lights. Through I'm willing to bet it's closer to actually being right than the coolant/trans temp gauges.
Right, all cars are like that, aren't they? That's why you drive for 100 miles or more before the gauge starts to move. The float is pinned against the top of the tank. After the harpoon, if its done right, you can drive even farther before it starts to move.
Well, use your own judgement. It's a big debate around here. My opinion is you should cut them both to minimize foam and maximize capacity.
The nozzle clicks off when the fuel level reaches the vent tube and is forced up into it, so all you need to cut is the vent tube. It won't hurt to cut the fill tube also but there is no reason to.
I only cut my vent tube and it works perfect
