Have had an F150 for a while, but just bought an E150 for my handyman business. It's a 2006 w/ 20,000 miles. I want to beef up the suspension and raise it a couple of inches. Any suggestions?
Hi there and welcome to the van world. The twin I-beams create some problems but a couple inches is probably do-able.
There are many threads already on raising van suspensions in this forum. I would suggest using the search feature here and while in the van forum, use some search terms like
lift suspension
I got a whole bunch of hits with a lot of info searching on those two words together. Airbags or new front springs seem to be the way to do it.
Higher capacity coils in the front (ie. from an E250) and Air Lift air bags or Timbrens in the rear would be the route I'd take. Im looking hard at Timbrens right now myself to eliminate the sag from a 1000# tounge weight trailer. It seems that Timbrens would work best when the load was heavy or
empty. Ie. full of sheet rock or empty.
Interesting looking at the Timbrens website though, anyone used Timbrens on an E350? Did you gain any height?
I just purchased a 2" front leveling kit from MaxxLift, which is a coil spacer, but haven't installed it yet. Since mine is an E350 I didn't want to go any heavier on the coils.
Timbrens don't add any height. They actually ride about a inch off the axle when empty and then as load increases, they come into contact and do their job. There is a digital animation somewhere (on You Tube?) that shows it very well.
If I can ask why raise the suspension------assuming you want to raise the body above the wheels and tires etc? Would this be to increase weight/towing capabilities or more for the look?
since he mentioned its for his handyman business, i would suspect that he's mostly looking for weight capacity, but he'll have to speak for himself to confirm that. assuming yes, just how much weight are we talking about here? stop by a scale somewhere on a day when loaded as heavy as you usually get and see what it weighs, if you're anywhere close to your tire ratings, you should upgrade to a heavier-duty tire along with the spring upgrade. i know in older F150s, the springs were usually capable of much more weight than the tires (load range C), i don't know how that changed in the newer years
