Fuel injectors
Old Oct 7, 2011 | 06:39 PM
weldworks54's Avatar
weldworks54
Fuel injectors
Anyone ever ran or use little power shop fuel injectors They are a shop in Pa they are selling new reman injectors on eBay fairly cheap. Just wonder how good they are? They give a 1 year unlimited mile warranty Thanks jason
Old Oct 7, 2011 | 06:43 PM
jkudera's Avatar
jkudera
thought about going with them but everyone on here said go factory
Old Oct 7, 2011 | 07:08 PM
sandmanf250's Avatar
sandmanf250
injectors
factory only.
Old Oct 8, 2011 | 06:12 AM
2006powerstroke90's Avatar
2006powerstroke90
I only buy mine from Ford also...
How much are they going for on eBay?
Old Oct 8, 2011 | 11:16 AM
NewToDiesels's Avatar
NewToDiesels
Got mine from Pensacola Diesel. Rebuilt OEM's for $195. Isn't that all that's available? Are Ford's new? As in never installed? I was under the impression that the dealership sold remans as well.
Old Oct 8, 2011 | 12:29 PM
jkudera's Avatar
jkudera
yeah oem are remanufactured. how much luck have you had with the pensacola ones? i looked at them but EVERYONE on here said stay with stock
Old Oct 8, 2011 | 12:47 PM
NewToDiesels
They are stock. They are OEM. Just re-manufactured. Forgot the name on the packaging - I think Alliant? I've had them installed about 6 weeks. Probably 3,000 miles - so it's early but truck has never run better. Just slipped them in, torqued 'em down, cranked for about 30 seconds and poof - trucks runs awesome after air was worked out by running down the road for a little while.
Old Oct 8, 2011 | 01:08 PM
jkudera's Avatar
jkudera
im goona be upset if yours work out ok the ones from ford were 200 dollars more for the set and that was going up one size from pensacola
Old Oct 8, 2011 | 02:14 PM
npccpartsman's Avatar
npccpartsman
Pensacola Diesel has a HORRIBLE reputation for 6.0 injectors. What Ford sells for remans and what everyone else sells for remans are NOT even in the same ball park. It's been rumored that Alliant was doing the reman. for Ford. That's not the case either. Ford uses NEW spool valves. Alliant reman's them.
Old Oct 8, 2011 | 02:16 PM
NewToDiesels
Learn something new everyday... That's why I hang around here. That would explain why they are cheaper... So far so good for me, but as I said, it's still early.
Old Oct 8, 2011 | 02:52 PM
npccpartsman
If Pensacola D. is using/reselling Alliant injectors that's not necessarily a bad thing. Alliant does decent work but a well respected injector builder had a lot of trouble with their remans and went to Ford remans with MUCH greater success. Pensacola had a good warranty but who wants to constantly be changing out injectors to get a good one? Hopefully you got a good set that runs a long time.
Old Oct 8, 2011 | 04:47 PM
weldworks54
The little power shop injectors are $200 each I haven't check with ford yet on price
Old Oct 8, 2011 | 04:56 PM
jkudera's Avatar
jkudera
I just got mine for 220 from dealer
Old Oct 8, 2011 | 05:28 PM
weldworks54
If I can get them for that from the dealer that's what I'll do
Old Oct 8, 2011 | 07:03 PM
weldworks54
I just checked tously ford and I can get them there for $220 each sounds like injector duty coming soon
95fiveoh
Feb 21, 2018 09:13 PM
Hardlanding
Dec 8, 2015 10:23 AM
Matt Wilson
Dec 22, 2004 05:16 PM
Jrock909
Oct 31, 2004 10:02 PM
