1996 7.3 no power
Old Oct 7, 2011 | 10:05 AM
Derrick21's Avatar
Derrick21
1996 7.3 no power
I have tried everything on my 1996 f250 7.3L nothing seems to help. it starts right up but idles real rough and if you hold the throttle to the floor it will gradually pickup rpmbut when driving it dosent have enough power to get out of third gear. i need help
Old Oct 7, 2011 | 10:29 AM
fordpride's Avatar
fordpride
Have you checked fuel pressure?
Unplug the electrical connection on the MAP sensor and see if that helps
Old Oct 7, 2011 | 11:34 AM
Derrick21's Avatar
Derrick21
hey thanks for the fast response, i unplugged the map and it helped alot but it still has some room for improvment. could you think of anything else it might be?
Old Oct 7, 2011 | 12:28 PM
fordpride's Avatar
fordpride
If it helped then your MAP sensor is bad.
Did you check fuel pressure?
You can check with a tire gauge. On the driver side of the fuel bowl you will see what look like the top of a valve stem check it there you want over 50psi.
How old is the fuel filter?
Old Oct 7, 2011 | 12:56 PM
Derrick21's Avatar
Derrick21
the fuel pressure at idle was between 50 and 60 psi but at wot it dropped down to around 30 and 40 psi
Old Oct 7, 2011 | 12:57 PM
Derrick21's Avatar
Derrick21
oh and the fuel filter has recently been changed
Old Oct 7, 2011 | 02:21 PM
Hussler's Avatar
Hussler
Both exhaust manifolds hot?
Sounds like you are running on only 1 bank.
Old Oct 7, 2011 | 02:32 PM
tshrager's Avatar
tshrager
Make sure the MAP tube isn't just plugged or dry rotted
koski19
May 8, 2020 01:35 AM
Catahoula
May 19, 2013 05:21 PM
hotweekend
15
May 15, 2013 09:45 PM
84300
Nov 24, 2010 02:09 PM
pitless
20
Aug 22, 2010 11:12 AM
