Flathead 239ci wiring
Old Oct 7, 2011 | 05:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
These are the kind I have, which may well be Ford Car types. They are a "cloverleaf" that is dipped in rubber at the holes where the wires go thru. I suspect both are supposed to be used for the driver's side wires, but I used one for the passenger side rear cylinders as part of the "whirlpool" routing I used. (You can see here why a lot of traditionalists don't like the MSD, it really is huge) One thing with the cloverleaf style brackets, no terminal except the stock bare elbows will pass thru them, so I had to build my wires after sticking them thru the brackets. (and someday I'll redo them with blue or gray wires, what can I say, I had the yeller ones on hand)
Old Oct 7, 2011 | 06:04 PM
52 M1 Kootenay Kid's Avatar
52 M1 Kootenay Kid
I did that last week.
Went to NAPA and got a set of 8 wires with factory molded 90 degree plug ends.The kit also included 8- 90 degree rubber caps for the distributor end,8 metal clips,and a pack of lube to aid in assembly.
All the wires are plenty long enough to trim and fit.
I recall it was $22.00
Cheers
Old Oct 7, 2011 | 07:28 PM
harleymsn's Avatar
harleymsn
Ross, I don't even know if those are actually Ford, I seem to recall that type on a 57 Caddy we had when I was a kid.
Here are the correct holders, part # 12297
Old Oct 7, 2011 | 08:45 PM
tinman52's Avatar
tinman52
Welder User
OK, those look familiar......I'll have to dig thru my parts again. I finally found a correct coil bracket....
Old Oct 7, 2011 | 08:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Joe, if you have the workshop manual, check out the pictures on p 93, Fig. 's 5 and 6. Scan below
Old Oct 7, 2011 | 09:06 PM
harleymsn's Avatar
harleymsn
I stand corrected. Didn't notice that one before.
Old Oct 7, 2011 | 09:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I hadn't either, just thought I'd take a look since it was sitting next to me. Note the cloverleaf type has a '50 engineering number, so may have been a 51-52 running change.
Old Oct 7, 2011 | 11:24 PM
52 Merc's Avatar
52 Merc
Re; plug ends, I've got a couple of really old used sets that have 90 degree rubber boots with a FoMoCo script molded in them.
I don't believe all of them had open terminals on the plug end.
N8RdaGR8R
Apr 6, 2019 01:52 PM
codyegan07
1983 - 2012 Ranger & B-Series
Jun 19, 2017 10:25 AM
Tylus
15
Jun 1, 2017 02:53 AM
black58
15
Apr 5, 2009 08:31 PM
