Con Rod Question
Old Oct 7, 2011 | 07:45 AM
oldmerc's Avatar
oldmerc
oldmerc
Con Rod Question
Hello folks
I hope this is not a stupid question.
We are in the process of rebuilding 49 8BA ,I notice the con rods
appear to have been welded over what I think is the oil squirt hole
What gives?
Allan
Old Oct 7, 2011 | 08:01 AM
4tl8ford's Avatar
4tl8ford
Pictures would help
Old Oct 7, 2011 | 08:58 AM
ALBUQ F-1's Avatar
ALBUQ F-1
It can't be good...
Are these the holes on the big end? Maybe a hail-Mary attempt to improve oil pressure? I can't think of anything else.
Old Oct 7, 2011 | 04:11 PM
BlueOvalRage's Avatar
BlueOvalRage
Yeahhh, those holes sorta need to be there. That's what lubes the camshaft and tappets. Modern oils with their low ZDDP levels are hard enough on cams the way they are let alone cutting off most of their lube completely. I think I'd try to find a good used set of rods rather than open them back up. Unless it is done under carefully controlled conditions, welding on cast iron is a bad idea on a critical high-stress piece like a connecting rod. It can cause microscopic stress fractures if it cools too quickly. Smells to me like an extra hole in an oil pan waiting to happen.
Old Oct 8, 2011 | 08:45 AM
38 coupe's Avatar
38 coupe
If you need replacement rods: Stock Rod 7" Set of 8 | SF Flatheads | SoCal Sacramento
Old Oct 8, 2011 | 09:31 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The stock rods are forgings, so you could open the holes back up, but the holes need to be a specific size. Depending whether they just laid a bead over the top of the hole or really got penetration, they might need re-drilling. Welding may have distorted the big end out-of-round, too. All in all, swapping to a different set is likely the economical way to go.
38 Coupe, I am shocked that those are brand new! Chinese? Unbelievable price. Any experience?
Old Oct 8, 2011 | 09:50 AM
oldmerc's Avatar
oldmerc
oldmerc
I believe I will try to drill them out ,resize and balance .
whats the worst that can happen
I'll bloww another engine up
Old Oct 8, 2011 | 10:15 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Well, then why drill them out? 59 engines used essentially the same rods with no holes. The holes were added when they upgraded to the bigger oil pump in 8BAs.
Old Oct 10, 2011 | 07:25 PM
38 coupe's Avatar
38 coupe
Those are new rods out of the French flatheads. The French government kept using flatheads in their military vehicles into the 1980s. Most all the flathead parts shown on that website are military surplus. I have purchase a set of French rods for one of my projects and they look good. Why recondition rods when you can buy a whole new set for the same price?
85e150
Garage & Workshop
May 5, 2015 11:26 PM
forss
Sep 5, 2012 08:05 PM
mbrowne
Flathead V8 & Flathead 6
Jun 9, 2012 09:41 AM
William
Dec 2, 2002 04:38 PM
unioncreek
Apr 1, 2002 08:22 AM
